1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject:
To: [email protected]
Date: Sat, 12 Nov 2022 11:26:05 +0800 (GMT+08:00)
Hi tech-talk-team,
I have intalled strawberry-perl-5.32.1.1-64bit in win10 64bit and set EPICS_HOST_ARCH=windows-x64-mingw, gmake base-R7.0.4.1 successfully. Also matlab 2020a was intalled.
then downloaded most recent epics-labca-master from github and extracted. According to labca document, set configure/  CONFIG and RELEASE as follows:
CONFIG:
    MAKEFOR=MATLAB
    CONFIG_USE_CTRLC=YES
RELEASE:
    EPICS_BASE=E:/LZ/base-R7.0.4.1
    MATLABDIR=D:/matlab
    MATLIB_SUBDIR=win64/mingw64
then gmake from epics-labca-master top.
gmake[2]: *** No rule to make target 'gitstring.c', needed by 'gitstring.obj'.  Stop.
gmake[2]: Leaving directory 'E:/LZ/epics-labca-master/glue/O.windows-x64-mingw'
gmake[1]: *** [E:/LZ/base-R7.0.4.1/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
gmake[1]: Leaving directory 'E:/LZ/epics-labca-master/glue'
gmake: *** [E:/LZ/base-R7.0.4.1/configure/RULES_DIRS:85: glue.install] Error 2
Any suggestions may be helpful!
Thanks a lot!
Prev: caQtDM .ui to CSS/Phoebus converter Laurenz Rettig via Tech-talk
Next: Re: vxworks boot problem Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
