Hi Sandeep,
Do you have a Firewall running?
I had a similar situation recently running the ADAravis driver where I could read all the information from the camera, but pressing start did nothing. After investigating with wireshark, I discovered it was a firewall blocking the data port.
I disabled that and SELinux and then everything worked.
Cheers, Andy
Hello
I have Allied Vision Alvium G1-2460m Camera and using ADVimba driver to interface the same. I can write/read all other camera parameters but can't see image streaming (the array counter is not running up). I have followed
this link to create template files. I get this message on IOC start
2022/11/14 05:13:00.331 Param[ACQ_PERIOD] GenICamFeature::write: node AcquisitionFrameRate is not writable
2022/11/14 05:13:00.359 Param[GC_FRAMERATE_ENABLE] GenICamFeature::write: node AcquisitionFrameRateEnable is not writable
2022/11/14 05:13:00.387 VimbaFeature:writeEnumIndex: ERROR calling SetValue error=-11
The contents of st.cmd are
# ADVimba driver
ADVimbaConfig("TEST1-CAM:CAM", 192.168.0.30, 0, 0,0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADVimba/db/vimba.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADGenICam/db/AVT_AlviumG1.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
# standard arrays plugin
NDStdArraysConfigure("TEST1-CAM:Image", 3, 0, "TEST1-CAM:CAM", 0, 0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADCore/db/NDStdArrays.template", "P=TEST1-CAM:,R=image1:,PORT=TEST1-CAM:Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=TEST1-CAM:CAM,TYPE=Int8,FTVL=UCHAR,NELEMENTS=24551424")
FYI, The software trigger source is selected which should capture the frame on every software trigger. Detector state is always in
waiting state. I have attached opi screenshot to confirm that camera interface works well.
Any suggestions would be appreciated.
Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- Re: Allied Vision Alvium Camera streaming issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
- Allied Vision Alvium Camera streaming issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Re: Disable PVs processing based on some condition Maren Purves via Tech-talk
<2022>
<2022>
ANJ, 14 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
