1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Epics Archiver Appliance requests and DST/Timezones
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>, Ralph Lange <[email protected]>
Date: Wed, 16 Nov 2022 05:23:46 +0000
Hello Adam
Yes you are right, and in the response, you get the timestamp in UTC and you convert it to local time. Although, I tried adding time zone offset in the request URL and it seems AA does support time zone offset (https://joda-time.sourceforge.net/apidocs/org/joda/time/format/ISODateTimeFormat.html#dateTime()), but the request always fail with code 404 because it is unable to parse the time stamp with time zone offset.
P.S.: If you request data with the “getData.csv” and “getData.json” requests you get time stamp in UTC but for some reason “getData.txt” returns local time.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Tuesday, November 15, 2022 10:38 PM
To: Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
Hi Abdalla/Ralph,
Thanks for the responses and sorry for my naïve questions as this has been confusing for me.
Ralph just to clarify the part about “clients should formulate their requests in UTC”, that means that I do need to account for the proper offset based off my time zone (and DST) to get the proper UTC timestamp correct for the URL request?  I think that matches what Abdalla had mentioned about the client application grabbing the offset as well.
Example
If I have a PV that is stored at 10am PST, the IOC time stamp stores it at UTC but it has to get the offset from the system clock to go from PST to UTC right (-8 in this case to get to UTC)?  Now if I want to get the PV in the archiver that was stored at 10am PST,  it seems I have two choices I either request it in UTC (had to add in the offset 10am + 8) 2012-012-27T18:00:00.000-000Z  or have the offset in the request 2012-012-27T10:00:00.000-800Z.  But either way it looks like I need to account timezone/dst for the request, unless I am misunderstanding something horribly.
Adam
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Tuesday, November 15, 2022 1:29 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Epics Archiver Appliance requests and DST/Timezones
I agree with Abdalla.
The idea is:
IOC timestamps are UTC (= no timezone, no DST). The archive engine puts those IOC timestamps into the archive, without changing them.
Clients should formulate their requests in UTC. The returned data will have the UTC timestamps from the archive.
In other words: The times are in UTC; any conversion to local time needs to happen at the client.
Cheers,
~Ralph
Epics Archiver Appliance requests and DST/Timezones Manoussakis, Adamandios via Tech-talk
RE: Epics Archiver Appliance requests and DST/Timezones Abdalla Ahmad via Tech-talk
Re: Epics Archiver Appliance requests and DST/Timezones Ralph Lange via Tech-talk
RE: Epics Archiver Appliance requests and DST/Timezones Manoussakis, Adamandios via Tech-talk
Prev: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Pete Jemian via Tech-talk
Next: RE: Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Epics Archiver Appliance requests and DST/Timezones Pete Jemian via Tech-talk
Next: Re: Epics Archiver Appliance requests and DST/Timezones Michael Davidsaver via Tech-talk
