1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Disable PVs processing based on some condition
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Wed, 16 Nov 2022 06:42:48 +0000
Hello Ralph
Thanks for your suggestion. This works well and even suitable as a runtime configuration without the need for an IOC but it has the same behavior as with the dfanout setup. I set SDIS to “TestPV CP” and DISV to the disable value and the PV does not get processed while TestPV equal DISV, If I change the PV while it is disabled, it will be processed with that value when TestPV is not equal to DISV.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, November 14, 2022 12:10 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Disable PVs processing based on some condition
On Mon, 14 Nov 2022 at 09:10, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I would like to disable processing for certain PVs based on some condition, I used the DISA field by writing 1 to it in a dfanout record from a calcout record (OUT field). The setup is working fine but with a strange behavior (which might be expected). Writing anything to DISA does not take effect until the PV is processed, so I had to make another fanout record only to process those PVs whenever the calcout record is processed (FLNK). Now assume if the condition is met and the PVs got disabled, if you write anything to the PV, it will not process it but on the next change from calcout. This can be problematic in certain setups. Is there any way to avoid writing at all when the PV is disabled? Or a better way to disable PVs? Thanks.
What about skipping the dfanouts / fanouts and just pointing the SDIS links of all to-be-conditionally-disabled records to the condition calc? If you make these SDIS links CP, the target records will be processed when the disable condition changes.
Cheers,
~Ralph
Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
Re: Disable PVs processing based on some condition Ralph Lange via Tech-talk
Prev: RE: Epics Archiver Appliance requests and DST/Timezones Abdalla Ahmad via Tech-talk
Next: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Disable PVs processing based on some condition Ralph Lange via Tech-talk
Next: Re: Disable PVs processing based on some condition Maren Purves via Tech-talk
