Subject: |
Re: [EXTERNAL] CSS Phoebus - Making certain points "invisible" on the plot |
"Hartman, Steven via Tech-talk" <[email protected]> |
To: |
"Wang, Andrew" <[email protected]> |
Cc: |
EPICS tech-talk <[email protected]> |
Date: |
Mon, 21 Nov 2022 21:31:05 +0000 |
Essentially, I have an array record of length n that could contain long values between 0 and 10000. I was wondering if there is a way to have points whose values are greater than 2000 but less than 4000 be invisible on the plot.
You could use two plots widgets adjacent to each other, both with the same PV, one plot configured with Y-axis Minimum = 0, Maximum = 2000 and the other plot configured with Minimum = 4000 and Maximum = 10000.
Steven Hartman
- CSS Phoebus - Making certain points "invisible" on the plot Wang, Andrew via Tech-talk
motorOMS module startupscript on target(MVME6100) running vxWorks6.9 whitetiger1123 via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
