1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: How to: IOC reading information from file?
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Thu, 24 Nov 2022 15:02:43 +0000
Hello all.
I want to create a set of configuration files (probably json, yaml or even txt) that i can make my IOC read and put the values into PVs. I could swear i read something about reading configuration files in EPICS documentation before but i cant for the life of me find it again.
Desired functionality would be something like:
file config0.yaml has: {"my_var" : 0}
file config1.yaml has: {"my_var" : 1}
And then i would have a record, say MYRECORD:Output that when i do:
caput MYRECORD:Output "config0.yaml"
the record would output 0 to its output link. And
caput MYRECORD:Output "config1.yaml"
the record would output 1 to its output link.
Is there any module or record that offers similar functionality?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Prev: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error whitetiger1123 via Tech-talk
Next: Changed source archive of StreamDevice release 2.8.22 NICOLE Remi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error Kevin Peterson via Tech-talk
Next: Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
