1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error
To: whitetiger1123 <[email protected]>
Date: Thu, 24 Nov 2022 18:45:17 +0000
Are you sure you have correctly set the jumpers on the board for A16 address space and address 0xF000?
You also need to set the address mode to something like “supervisory data” but I forget the exact setting and I don’t have access to our annotated manual today.
Sent from my iPhone
On Nov 24, 2022, at 12:29 PM, whitetiger1123 via Tech-talk <[email protected]> wrote:
Hello all,
While running EPICS ioc startup script st.cmd on vxWorks for an app that was made successfully, I am getting following error
I want to use OMS MAXv with load DB file and set board configure..etc.
This is my error:
Vxworks
< cdCommands
startup = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
New symbol "startup" added to kernel symbol table.
startup = 0x44f7f50: value = 72396944 = 0x450b090
putenv("IOC=iocOms")
value = 0 = 0x0
top = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC"
New symbol "top" added to kernel symbol table.
top = 0x450b040: value = 72397168 = 0x450b170 = 'p' = top + 0x130
putenv("TOP=/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC")
value = 0 = 0x0
topbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/bin/vxWorks-ppc32"
New symbol "topbin" added to kernel symbol table.
topbin = 0x4505de0: value = 72375856 = 0x4505e30 = '0' = topbin + 0x50
motor = "/home/test/epics/synApps_6_1/support/motor-R7-1"
New symbol "motor" added to kernel symbol table.
motor = 0x4505db0: value = 72376016 = 0x4505ed0 = topbin + 0xf0
putenv("MOTOR=/home/test/epics/synApps_6_1/support/motor-R7-1")
value = 0 = 0x0
motorbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/bin/vxWorks-ppc32"
New symbol "motorbin" added to kernel symbol table.
motorbin = 0x4505fd0: value = 72398512 = 0x450b6b0 = top + 0x670
asyn = "/home/test/epics/synApps_6_1/support/asyn-R4-36"
New symbol "asyn" added to kernel symbol table.
asyn = 0x450b710: value = 72398688 = 0x450b760 = '`' = asyn + 0x50
putenv("ASYN=/home/test/epics/synApps_6_1/support/asyn-R4-36")
value = 0 = 0x0
asynbin = "/home/test/epics/synApps_6_1/support/asyn-R4-36/bin/vxWorks-ppc32"
New symbol "asynbin" added to kernel symbol table.
asynbin = 0x450b850: value = 72399008 = 0x450b8a0 = asynbin + 0x50
sncseq = "/home/test/epics/synApps_6_1/support/seq-2-2-6"
New symbol "sncseq" added to kernel symbol table.
sncseq = 0x450b7f0: value = 72326896 = 0x44f9ef0
putenv("SNCSEQ=/home/test/epics/synApps_6_1/support/seq-2-2-6")
value = 0 = 0x0
sncseqbin = "/home/test/epics/synApps_6_1/support/seq-2-2-6/bin/vxWorks-ppc32"
New symbol "sncseqbin" added to kernel symbol table.
sncseqbin = 0x450bb60: value = 72399792 = 0x450bbb0 = sncseqbin + 0x50
busy = "/home/test/epics/synApps_6_1/support/busy-R1-7-2"
New symbol "busy" added to kernel symbol table.
busy = 0x44f9fe0: value = 72399920 = 0x450bc30 = '0' = sncseqbin + 0xd0
putenv("BUSY=/home/test/epics/synApps_6_1/support/busy-R1-7-2")
value = 0 = 0x0
busybin = "/home/test/epics/synApps_6_1/support/busy-R1-7-2/bin/vxWorks-ppc32"
New symbol "busybin" added to kernel symbol table.
busybin = 0x450bd30: value = 72400256 = 0x450bd80 = busybin + 0x50
ipac = "/home/test/epics/synApps_6_1/support/ipac-2-15"
New symbol "ipac" added to kernel symbol table.
ipac = 0x450bde0: value = 72400432 = 0x450be30 = '0' = ipac + 0x50
putenv("IPAC=/home/test/epics/synApps_6_1/support/ipac-2-15")
value = 0 = 0x0
epics_base = "/home/test/epics/base-3.15.6"
New symbol "epics_base" added to kernel symbol table.
epics_base = 0x450bf00: value = 72400720 = 0x450bf50 = 'P' = epics_base + 0x50
putenv("EPICS_BASE=/home/test/epics/base-3.15.6")
value = 0 = 0x0
epics_basebin = "/home/test/epics/base-3.15.6/bin/vxWorks-ppc32"
New symbol "epics_basebin" added to kernel symbol table.
epics_basebin = 0x450bfd0: value = 72372384 = 0x45050a0
< ../nfsCommands
#Instructions for creating and using a real nfsCommands file
# in order to use nfs do the following:
# 1) Create hostAdd and nfsMount commands for each nfs server
# 2) In each st.cmd file add the following two commands BEFORE any load commands
#    ../nfs.cmd
#    cd "<iocname>
# The hostAdd command has the form:
# hostAdd("<host>","xxx.xxx.xxx.xxx")
# The vxWorks nfsMount command has the form:
# nfsMount("<host>")
# You can also mount subdirectories as follows:
# nfsMount("<host>", "/xxx/xxx/xxx", "/xxx")
# For example assume
# host is mercury with inet address 155.77.2.56
# You want to mount the directory (which is a file system of mercury)
# /home/mercury5/iocinfo
#    as
# /iocinfo
# The commands would be
# hostAdd("mercury","155.77.2.56")
# nfsMount("mercury","/home/mercury5/iocinfo","/iocinfo")
cd topbin
value = 0 = 0x0
## You may have to change oms to something else
## everywhere it appears in this file
ld 0,0, "oms.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot.  For reduced functionality, call
    rebootHookAdd(epicsExitCallAtExits)
value = 72372448 = 0x45050e0
cd top
value = 0 = 0x0
dbLoadDatabase "dbd/oms.dbd"
value = 0 = 0x0
oms_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
cd startup
value = 0 = 0x0
## motorUtil (allstop & alldone)
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=oms:")
value = 0 = 0x0
cd "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
value = 0 = 0x0
## Support for the OMS MAXv (VxWorks shell or iocsh)
< MAXv.cmd
dbLoadTemplate("MAXv.substitutions")
value = 0 = 0x0
# OMS MAXv driver setup parameters:
#     (1)number of cards in array.
#     (2)VME Address Space - A(16,24,32).
#     (3)Base Address (see motorOms/omsApp/src/README).
#     (4)interrupt vector (0=disable or  64 - 255).
#     (5)interrupt level (2 - 6).
#     (6)motor task polling rate (min=1Hz,max=60Hz).
MAXvSetup(1, 16,     0xF000, 0, 5, 10)
value = 0 = 0x0
#!MAXvSetup(1, 24,   0xFF0000, 200, 5, 10)
#!MAXvSetup(1, 32, 0xFF000000, 200, 5, 10)
#!drvMAXvdebug=4
# OMS MAXv configuration string:
#     (1) number of card being configured (0-14).
#     (2) configuration string; axis type (PSO/PSE/PSM) MUST be set here.
#         For example, set which TTL signal level defines an active limit
#         switch.  The "config" example below sets X,Y,Z,T to active low (LTL),
#         sets U,V,R,S to active high (LTH) and sets all axes to open-loop
#         stepper (PSO). See MAXv User's Manual for LTL/LTH and PSO/PSE/PSM
#         commands.
#         config="AX LTL PSO; AY LTL PSO; AZ LTL PSO; AT LTL PSO; AU LTH PSO; AV LTH PSO; AR LTH PSO; AS LTH PSO;"
#     (3) SSI based absolute encoder bit flag. Bit #0 for Axis X, bit #1 for
#         Axis Y, etc.. Set a bit flag to '1' for absolute encoder values; '0'
#         for the standard incremental encoder values.
#     (4) SSI based absolute encoder grey code flags (0/1 - yes/no, 0x12 -> UY)
# The max command-line length of the VxWorks shell is 128 chars
str = malloc(200);
New symbol "str" added to kernel symbol table.
str = 0x4555ed0: value = 72728064 = 0x455be00
strcpy str, "AA; LMH,H,H,H,H,H,H,H;"
strcat str, "AX LTH PSO; AY LTH PSO; AZ LTL PSO; AT LTL PSO; AU LTL PSO; AV LTL PSO; AR LTL PSO; AS LTL PSO;"
MAXvConfig(0, str, 0, 0)
value = 0 = 0x0
free(str)
value = 0 = 0x0
< MAXv.iocsh
value = 0 = 0x0
MAXvSetup(1, 16,     0xF000, 200, 5, 10)
value = 0 = 0x0
#!drvMAXvdebug=4
#         commands.
epicsEnvSet("config0", "AA; LMH,H,H,H,H,H,H,H; AX LTH PSO; AY LTH PSO; AZ LTL PSO; AT LTL PSO; AU LTL PSO; AV LTL PSO; AR LTL PSO; AS LTL PSO;")
value = 0 = 0x0
MAXvConfig(0, "$(config0)", 0, 0)
value = 0 = 0x0
## Support for the OMS VME85
#< VME58.cmd
## Support for the OMS VME8 and VME44
#< VME8.cmd
## Support for the OMS PC68 and PC78 (requires asyn)
#< PC68.cmd
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
iocInit: Time provider has not yet synchronized.
Illegal field value PV: oms:m2 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m3 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m4 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m5 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m6 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m7 motor_init_record_com(): card does not exist!
Illegal field value PV: oms:m8 motor_init_record_com(): card does not exist!
value = 0 = 0x0
motorUtilInit("oms:")
value = 0 = 0x0
# Boot complete
Done executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'.
Am I set MAXvSetup and MAXvConfig wrong? Or do I have to load another db(currently is motorUtil.db)?
I’d like to know what happens with this and fix this error.
I hope you understand Iam new to the world of EPICS. Casual I’ve been trying to understand them for 3 days. From there to before he knew nothing of them.
I hope you can help.
Thanks and regards.
Re: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error Kevin Peterson via Tech-talk
Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error whitetiger1123 via Tech-talk
Prev: Re: Changed source archive of StreamDevice release 2.8.22 Zimoch Dirk (PSI) via Tech-talk
Next: EPICS nfs mount issues whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error whitetiger1123 via Tech-talk
Next: Re: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error Kevin Peterson via Tech-talk
