1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Using DPVT for non-device support purposes
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 25 Nov 2022 18:34:11 +0000
All,
I was wondering about the use of the dpvt pointer in a subroutine that the aSub record uses when it is processed. My understanding is that the dpvt pointer is used for device support, but I was wondering if it can also be used as an alternative to static variables.
For instance, suppose I have a very simple asub record called count$(N) and I have two instances of it called count1 and count2. I want to keep track of the number of times that each of them have been processed. If my subroutine code is the following:
static long count_static(aSubRecord *prec)
      long status = 0;
        static int count = 1;
        printf("I have been called %d time(s)\n", count);
        count++;
      return status;
epicsRegisterFunction(count_static);
and I do the following in a terminal:
caput count1.PROC 1
caput count1.PROC 1
caput count1.PROC 1
caput count1.PROC 1
caput count2.PROC 1
Then I get the messages:
I have been called 1 time(s)
I have been called 2 time(s)
I have been called 3 time(s)
I have been called 4 time(s)
I have been called 5 time(s)
This is wrong, because count2 was only called once.
If, however, I use the following subroutine code:
static long count(aSubRecord *prec)
      long status = 0;
    if (!prec->dpvt)
        prec->dpvt = (int *) calloc(1, sizeof(int));
    if (prec->dpvt)
        *((double *) prec->dpvt) += 1;
          printf("I have been called %d time(s)\n", *((int *) prec->dpvt));
    else
        status = -1;
      return status;
epicsRegisterFunction(count);
Then, if I run the same caputs, I get the messages:
which is correct, since I only processed count2 once.
Is it okay to use dpvt pointer for "static" variable-like behavior or should a different methodology be used since dpvt pointer seems to be meant for device support.
An additional related question: Suppose for device support, dpvt pointer points to a struct, which has a special free function associated with it (the struct might contain member variables that are dynamically allocated). Where can that be called so that there is no memory leaks from the IOC?
Andy
Re: Using DPVT for non-device support purposes Andrew Johnson via Tech-talk
Prev: RE: EPICS nfs mount issues Mark Rivers via Tech-talk
Next: Re: Using DPVT for non-device support purposes Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: mca R7-10 available Mark Rivers via Tech-talk
