1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Fw: motor control css problem
Date: Mon, 5 Dec 2022 13:43:12 +0000
Closing issue with tech-talk.
Sent: Sunday, December 4, 2022 11:29 PM
Subject: RE: motor control css problem
I set the configuration string to reflect the physical switch configuration as you said,
Now it works! Thanks!
Windows용 메일에서 발송된 메일입니다.
보낸 사람: Mark Rivers
보낸 날짜: 2022년 12월 5일 월요일 오후 1:53
받는 사람: whitetiger1123
참조: [email protected]
제목: Re: motor control css problem
Does you motor have a limit switch? If so is the switch open when the motor hits the limit, or closed when it hits the limit?
You need to set the configuration string to reflect the physical switch configuration.
You have set the readback to be oms:m1. That is not correct, that field is used for an external readback device like an LVDT. Leave that field blank.
When you move the motor in the other direction does it also show a limit?
Sent from my iPhone
On Dec 4, 2022, at 10:24 PM, whitetiger1123 via Tech-talk <[email protected]> wrote:
Hi, now I’m going to test the motor control from now on.
Before I ask a question, I would like to thank the epics tech talk for helping me this step.
I’m a beginner in epics and RTOS, but I was able to come to this step with a lot of help. Really appreciate it.
I booted MVME6100 with epics st.cmd, MAXv controller. Now I’m trying to control motor use CSS.
I connected epics pv with css pv. And then I try to move this motor to +, the motor doesn’t work.
vxWorks system boot
snipped..
ld 0,0, "oms.munch"
cd top
dbLoadDatabase "dbd/oms.dbd"
oms_registerRecordDeviceDriver pdbbase
cd startup
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=oms:")
< MAXv.cmd
dbLoadTemplate("MAXv.substitutions")
MAXvSetup(1, 16,     0xF000, 200, 5, 10)
str = malloc(200);
strcpy str, "AA; LMH,H,H,H,H,H,H,H;"
strcat str, "AX LTH PSE; AY LTH PSO; AZ LTL PSO; AT LTL PSE; AU LTL PSE; AV LTL PSE; AR LTL PSE; AS LTL PSE;"
MAXvConfig(0, str, 0, 0)
free(str)
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
## motorUtil (allstop & alldone)
motorUtilInit("oms:")
# Boot complete
Done executing startup script '/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'.
The motor is “pk545nbw” oriental motor, 5 phase stepper motor.
1.     I set correct pv and phase to motorx_setup at
2.     And then when I try to click this(>) button, it doesn’t move any more.
0.00200 is the all I can move on css and real motor is not
3.     Is it because of this limit at motorx_all?
If it does not move because of this limit, how can I remove
Does anyone know how to resolve this problem? Please help me or give me any suggestions.
Thanks
motor control css problem whitetiger1123 via Tech-talk
Re: motor control css problem Mark Rivers via Tech-talk
Prev: RE: Archiver Appliance: How to extract a PV current value using a SQL query Abdalla Ahmad via Tech-talk
Next: Eurotherm2604 modbus support Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: motor control css problem Mark Rivers via Tech-talk
Next: Archiver Appliance: How to extract a PV current value using a SQL query Oscar Ibañez via Tech-talk
