1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: vxworks booting werid script and I can't moving motor
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Tue, 13 Dec 2022 16:11:37 +0900
Hi, Recently I set up booting vxworks and I saw my motor stage moving well.
But today I try to moving motor stage, it does not connect CSS.
I set up css ip(edit>preferences>css core>epics>addr_list as 10.4.49.170) correctly.
When I booting vxworks, I can see this weird script. I’ve never seen this script before when I booting vxworks
This is my weird script:
## Support for the OMS MAXv (VxWorks shell or iocsh)
< MAXv.cmd
dbLoadTemplate("MAXv.substitutions")
value = 0 = 0x0
# OMS MAXv driver setup parameters:
#     (1)number of cards in array.
#     (2)VME Address Space - A(16,24,32).
#     (3)Base Address (see motorOms/omsApp/src/README).
#     (4)interrupt vector (0=disable or  64 - 255).
#     (5)interrupt level (2 - 6).
#     (6)motor task polling rate (min=1Hz,max=60Hz).
MAXvSetup(1, 16,     0xF000, 200, 5, 10)
value = 0 = 0x0
#!MAXvSetup(1, 24,   0xFF0000, 200, 5, 10)
#!MAXvSetup(1, 32, 0xFF000000, 200, 5, 10)
#!drvMAXvdebug=4
# OMS MAXv configuration string:
#     (1) number of card being configured (0-14).
#     (2) configuration string; axis type (PSO/PSE/PSM) MUST be set here.
#         For example, set which TTL signal level defines an active limit
#         switch.  The "config" example below sets X,Y,Z,T to active low (LTL),
#         sets U,V,R,S to active high (LTH) and sets all axes to open-loop
#         stepper (PSO). See MAXv User's Manual for LTL/LTH and PSO/PSE/PSM
#         commands.
#         config="AX LTL PSO; AY LTL PSO; AZ LTL PSO; AT LTL PSO; AU LTH PSO; AV LTH PSO; AR LTH PSO; AS LTH PSO;"
#     (3) SSI based absolute encoder bit flag. Bit #0 for Axis X, bit #1 for
#         Axis Y, etc.. Set a bit flag to '1' for absolute encoder values; '0'
#         for the standard incremental encoder values.
#     (4) SSI based absolute encoder grey code flags (0/1 - yes/no, 0x12 -> UY)
# The max command-line length of the VxWorks shell is 128 chars
str = malloc(200);
New symbol "str" added to kernel symbol table.
str = 0x4521ed0: value = 72530704 = 0x452bb10
strcpy str, "AA; LMH,H,H,H,H,H,H,H;"
strcat str, "AX LTH PSO; AY LTH PSO; AZ LTL PSO; AT LTL PSO; AU LTL PSO; AV LTL PSO; AR LTL PSO; AS LTL PSO;"
MAXvConfig(0, str, 0, 0)
value = 0 = 0x0
free(str)
value = 0 = 0x0
#< MAXv.iocsh
## Support for the OMS VME85
#< VME58.cmd
## Support for the OMS VME8 and VME44
#< VME8.cmd
## Support for the OMS PC68 and PC78 (requires asyn)
#< PC68.cmd
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
data access
Exception current instruction address: 0x0x0497f08400
Machine Status Register: 0x1347d80000 b032
Data Access Register: 0xvxTaskEnt91014100ry
Condition Register: 0x  28000284+0x
Data storage interrupt Register: 0x4842000000
: 0x0022bbbc ()
0x0022bbbc shellTask    +0x488: shellExec ()
0x0022b6b0 shellExec    +0x12c: 0x0021ea30 ()
0x0021ec64 shellInterpCInit+0x3f0: shellInterpCparse ()
0x0021e590 shellInterpCparse+0xa5c: 0x00221668 ()
0x00221698 shellInterpCInit+0x2e24: 0x00221a28 ()
0x00221a68 shellInterpCInit+0x31f4: 0x00221b24 ()
0x00221be0 shellInterpCInit+0x336c: shellInternalFunctionCall ()
0x00219790 shellInternalFunctionCall+0xac : 0x04a58bb8 ()
0x04a58bd0 iocInit      +0x1c : iocBuild ()
0x04a58b50 iocBuild     +0x60 : 0x04a585d8 ()
0x04a58670 iocRun       +0x8f4: 0x0497fd20 ()
0x049800d4 MAXV_send_recv_mess+0xd38: 0x0497ef1c ()
Done executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'.
I can see my pv is well when I typed “dbl”
oms:m1_vCh
oms:m1_twCh
oms:m2_vCh
oms:m2_twCh
oms:m3_vCh
oms:m3_twCh
oms:m4_vCh
oms:m4_twCh
oms:m5_vCh
oms:m5_twCh
oms:m6_vCh
oms:m6_twCh
oms:m7_vCh
oms:m7_twCh
oms:m8_vCh
oms:m8_twCh
oms:m1
oms:m2
oms:m3
oms:m4
oms:m5
oms:m6
oms:m7
oms:m8
oms:movingDiff
oms:alldone
oms:alldoneBlink
oms:allstop
oms:m1_able
oms:m2_able
oms:m3_able
oms:m4_able
oms:m5_able
oms:m6_able
oms:m7_able
and css motor opi’s pv is oms:m1 and oms:m2.
I really want to know how to fix this problem
thanks
Prev: RE: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Next: Agilent IPC mini Controller (Ion Pump) William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Checking CPU and memory usage for an IOC Simon Rose via Tech-talk
