1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Possible to create aliases for record fields?
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Li, Ji" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Dec 2022 13:16:02 -0600
On 12/20/22 12:49 PM, Li, Ji via Tech-talk wrote:
I'm trying to access record fields as PVs using alias command, such as:
alias("det1.NELM", "det1:NELM")
alias("det1.TSEN", "det1:TSEN")
If alias command is not the right choice, are there any ways to create aliases/dummy PVs for fields?
I think it's possible to use a Channel Access PV Gateway to alias specific record fields to another PV name, but if you're looking for high performance through those channels there might be reasons for not wanting to doing that.
This is one of the few circumstances when the gateway's client and server sides could be on the same network, and you would need to be careful when configuring it to prevent loops. The alias configuration data would also be a long way from the IOC configuration, so updating both simultaneously would need care.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Possible to create aliases for record fields? Li, Ji via Tech-talk
Prev: Re: Possible to create aliases for record fields? Li, Ji via Tech-talk
Next: Re: Possible to create aliases for record fields? Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
