1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Phoebus Alarm Log panel
From: "Shroff, Kunal via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, William F Badgett Jr <badgett at fnal.gov>
Date: Mon, 9 Jan 2023 15:31:55 +0000
Hello William,
We recently upgraded the alarm-logger service to use elastic 8.
I have created a PR fixing the documentation (thanks for brining this to our attention)
https://github.com/ControlSystemStudio/phoebus/pull/2501
Additionally, the Phoebus client was updated to use the REST interface to the alarm-logger service instead of directly querying elastic... this way in the future we should avoid the situation you are currently facing where the client needs to be updated everytime we have to upgrade or make changes to the backend.
If you want to migrate your data from the old elastic 6 backend to elastic 8 (except if you are running elastic in docker containers during the codeathon this was the one scenario we were not able to address)
Instructions for data migration are in this discussion https://github.com/ControlSystemStudio/epics-codeathon-2022/discussions/5
Cheers,
Kunal
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of William F Badgett Jr via Tech-talk <tech-talk at aps.anl.gov>
Sent: 03 January 2023 16:45
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Phoebus Alarm Log panel
Hello all,
I am trying to display Phoebus alarm-logger entries from an elastic-search instance using the "Alarm Log Table" panel.
I built Phoebus locally from the latest master branch on GitHub.com , but I'm getting errors from elastic-search, like:
 2023-01-03 15:42:56 WARNING [org.phoebus.framework.jobs] Job 'searching alarm log messages for : *' failed
com.sun.jersey.api.client.UniformInterfaceException: GET http://xxx.yyy.zzz:9201/search/alarm?current_message=*&severity=*&current_severity=*&size=10000&pv=*&root=*&host=*&start=7+days&end=now&message=*&user=*&command=* returned a response status of 405 Method Not Allowed
Looking at the elastic-search with Kibana and curl, the data there look perfectly fine.  We have tried elastic-search v6 and v7 with the same problem.
How do we get this work?
Thanks
William Badgett
Accelerator Division Controls
Neutrino Division Operations
Fermi National Accelerator Lab
Kirk and Wilson Roads
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
badgett at fnal.gov
Phoebus Alarm Log panel William F Badgett Jr via Tech-talk
Prev: Re: Help: Asyn record getting incomplete input Mark Rivers via Tech-talk
Next: Re: Help: Asyn record getting incomplete input Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Phoebus Alarm Log panel William F Badgett Jr via Tech-talk
Next: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
ANJ, 09 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
