1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP)
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Jan 2023 16:49:48 +0000
On Fri, 2023-01-20 at 16:16 +0000, Leblanc, Gregory via Tech-talk wrote:
> Hi folks,
> I feel like I'm close to getting EPICS to talk to our Keysight measurement mainframes but can't quite get there.  I don't see any errors when I start the IOC with st.cmd until after iocRun, at which point it reports :
> 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000 ms to "*IDN?"
> 2023/01/20 11:08:25.869293 LAN0 swag5testIDNwf: No reply within 1000 ms to "*IDN?"
> How do I get some more debugging messages?  Maybe some capture of what it's sending?  I think it's getting no response because asynReport 10 LAN0 shows:
> LAN0 multiDevice:No canBlock:Yes autoConnect:Yes
>     enabled:Yes connected:Yes numberConnects 1
>     nDevices 0 nQueued 0 blocked:No
>     asynManagerLock:No synchronousLock:No
>     exceptionActive:No exceptionUsers 12 exceptionNotifys 0
>     traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
>     interposeInterfaceList
>         asynOctet pinterface 0x7fd4a97e7820 drvPvt 0xd13f40
>     interfaceList
>         asynCommon pinterface 0x7fd4a97e3e30 drvPvt 0xd106d0
>         asynOption pinterface 0x7fd4a97e3e50 drvPvt 0xd106d0
>         asynOctet pinterface 0xd107f0 drvPvt 0xd106d0
>     Port 10.0.0.105:5025: Connected
>                     fd: 4
>     Characters written: 10
>        Characters read: 0
> I also did a basic test using telnet and got a reasonable response.  Below I've added the output from running st.cmd.
You can get debug infos from asyn (asynTraceSomething), but you already got
some: "Characters read: 0" The device did not reply.
You may try to change your terminators.
Dirk
> #!../../bin/linux-x86_64/swag5test
> # Set up environment
> < envPaths
> epicsEnvSet("IOC","iocswag5test")
> epicsEnvSet("TOP","/home/leblanc/EPICS/TEST/swag5")
> epicsEnvSet("EPICS_BASE","/home/leblanc/EPICS/epics-base")
> epicsEnvSet("SUPPORT","/home/leblanc/EPICS/support")
> epicsEnvSet("ASYN","/home/leblanc/EPICS/support/asyn")
> epicsEnvSet("CALC","/home/leblanc/EPICS/support/calc")
> epicsEnvSet("STREAM","/home/leblanc/EPICS/support/StreamDevice")
> epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/leblanc/EPICS/TEST/swag5/db"
> # Allow PV name prefixes and serial port name to be set from the environment
> epicsEnvSet "P" "swag5"
> epicsEnvSet "R" "test"
> epicsEnvSet "HOST" "192.168.1.111"
> epicsEnvSet "PORT" "5025"
> ## Register all support components
> cd "/home/leblanc/EPICS/TEST/swag5"
> dbLoadDatabase "dbd/swag5test.dbd"
> swag5test_registerRecordDeviceDriver pdbbase
> # Set up ASYN ports
> drvAsynIPPortConfigure("LAN0","10.0.0.105:5025",0,0,0)
> #1st argument is the port's name
> #2nd argument is the "IP address: port num"
> #3rd argument is priority; 0 means medium
> #4th argument is noAutoConnect; 0 means yes, autoconnect
> #5th argument is noProcessEOS; 0 means do not close connection on timeout, 1 means close it
> var streamError 1
> var streamDebug 1
> var streamDebugColored 1
> var streamErrorDeadTime 30
> var streamMsgTimeStamped 1
> streamSetLogfile("logfile.txt")
> ## Load record instances
> dbLoadRecords("db/devswag5.db","P=swag5,R=test,PORT=LAN0,A=0")
> ## Start EPICS
> cd "/home/leblanc/EPICS/TEST/swag5/iocBoot/iocswag5test"
> iocInit
> Starting iocInit
> ## EPICS R7.0.7.1-DEV
> ## Rev. R7.0.7-5-g0f8ea3aa3671cb0433b4
> ## Rev. Date Git: 2022-09-25 09:34:13 -0700
> iocRun: All initialization complete
> epics> 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000 ms to "*IDN?"
> Gregory Leblanc
> Accelerator Engineer
> Edwards Accelerator Lab - Ohio University
> 123 University Terrace
> Athens, OH 45701 USA
> [email protected]
> M: (401) 52-OUAL1 or (401) 526-8251
RE: [External] Re: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
RE: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Mark Rivers via Tech-talk
Prev: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
Next: RE: [External] Re: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
