Beautiful, thanks! I added
asynOctetSetOutputEos("LAN0", -1, "\n")
immediately after the LAN0 setup line and started getting responses!
Greg
> -----Original Message-----
> From: Zimoch Dirk <[email protected]>
> Sent: Friday, January 20, 2023 11:50 AM
> To: Leblanc, Gregory <[email protected]>; [email protected]
> Subject: [External] Re: SCPI StreamDevice troubleshooting (Keysight 34980A via
> TCP)
> Use caution with links and attachments.
> On Fri, 2023-01-20 at 16:16 +0000, Leblanc, Gregory via Tech-talk wrote:
> > Hi folks,
> > I feel like I'm close to getting EPICS to talk to our Keysight measurement
> mainframes but can't quite get there. I don't see any errors when I start the IOC
> with st.cmd until after iocRun, at which point it reports :
> > 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000 ms to
> "*IDN?"
> > 2023/01/20 11:08:25.869293 LAN0 swag5testIDNwf: No reply within 1000 ms
> to "*IDN?"
> > How do I get some more debugging messages? Maybe some capture of what
> it's sending? I think it's getting no response because asynReport 10 LAN0 shows:
> > LAN0 multiDevice:No canBlock:Yes autoConnect:Yes
> > enabled:Yes connected:Yes numberConnects 1
> > nDevices 0 nQueued 0 blocked:No
> > asynManagerLock:No synchronousLock:No
> > exceptionActive:No exceptionUsers 12 exceptionNotifys 0
> > traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
> > interposeInterfaceList
> > asynOctet pinterface 0x7fd4a97e7820 drvPvt 0xd13f40
> > interfaceList
> > asynCommon pinterface 0x7fd4a97e3e30 drvPvt 0xd106d0
> > asynOption pinterface 0x7fd4a97e3e50 drvPvt 0xd106d0
> > asynOctet pinterface 0xd107f0 drvPvt 0xd106d0
> > Port 10.0.0.105:5025: Connected
> > fd: 4
> > Characters written: 10
> > Characters read: 0
> > I also did a basic test using telnet and got a reasonable response. Below I've
> added the output from running st.cmd.
> You can get debug infos from asyn (asynTraceSomething), but you already got
> some: "Characters read: 0" The device did not reply.
> You may try to change your terminators.
> Dirk
> > #!../../bin/linux-x86_64/swag5test
> > # Set up environment
> > < envPaths
> > epicsEnvSet("IOC","iocswag5test")
> > epicsEnvSet("TOP","/home/leblanc/EPICS/TEST/swag5")
> > epicsEnvSet("EPICS_BASE","/home/leblanc/EPICS/epics-base")
> > epicsEnvSet("SUPPORT","/home/leblanc/EPICS/support")
> > epicsEnvSet("ASYN","/home/leblanc/EPICS/support/asyn")
> > epicsEnvSet("CALC","/home/leblanc/EPICS/support/calc")
> > epicsEnvSet("STREAM","/home/leblanc/EPICS/support/StreamDevice")
> > epicsEnvSet "STREAM_PROTOCOL_PATH"
> "/home/leblanc/EPICS/TEST/swag5/db"
> > ######### # Allow PV name prefixes and serial port name to be set from
> > the environment epicsEnvSet "P" "swag5"
> > epicsEnvSet "R" "test"
> > epicsEnvSet "HOST" "192.168.1.111"
> > epicsEnvSet "PORT" "5025"
> > ## Register all support components
> > cd "/home/leblanc/EPICS/TEST/swag5"
> > dbLoadDatabase "dbd/swag5test.dbd"
> > swag5test_registerRecordDeviceDriver pdbbase
> > # Set up ASYN ports
> > drvAsynIPPortConfigure("LAN0","10.0.0.105:5025",0,0,0)
> > #1st argument is the port's name
> > #2nd argument is the "IP address: port num"
> > #3rd argument is priority; 0 means medium #4th argument is
> > noAutoConnect; 0 means yes, autoconnect #5th argument is noProcessEOS;
> > 0 means do not close connection on timeout, 1 means close it
> > var streamError 1
> > var streamDebug 1
> > var streamDebugColored 1
> > var streamErrorDeadTime 30
> > var streamMsgTimeStamped 1
> > streamSetLogfile("logfile.txt")
> > ## Load record instances
> > dbLoadRecords("db/devswag5.db","P=swag5,R=test,PORT=LAN0,A=0")
> > ## Start EPICS
> > cd "/home/leblanc/EPICS/TEST/swag5/iocBoot/iocswag5test"
> > iocInit
> > Starting iocInit
> > ## EPICS R7.0.7.1-DEV
> > ## Rev. R7.0.7-5-g0f8ea3aa3671cb0433b4 ## Rev. Date Git: 2022-09-25
> > 09:34:13 -0700
> > iocRun: All initialization complete
> > epics> 2023/01/20 11:08:24.866492 LAN0 swag5testIDN: No reply within 1000
> ms to "*IDN?"
> to "*IDN?"
> > Gregory Leblanc
> > Accelerator Engineer
> > Edwards Accelerator Lab - Ohio University
> > 123 University Terrace
> > Athens, OH 45701 USA
> > [email protected]
> > M: (401) 52-OUAL1 or (401) 526-8251
- SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Leblanc, Gregory via Tech-talk
- Re: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Zimoch Dirk via Tech-talk
RE: SCPI StreamDevice troubleshooting (Keysight 34980A via TCP) Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
