1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Keysight 34980A SCPI StreamDevice
From: "Leblanc, Gregory via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 24 Jan 2023 17:59:36 +0000
Hi again,
Still trying to run down some more details about talking to these lovely Keysight boxes via EPICS.  I've got the stock SCPI stuff working, so next I wanted to read some resistance values.  I added this to my protocol file:
getResistance {
    out "measure:resistance? \$1,\$2,\$3";
    in "%E";
And added this to my .db file:
record(longin, "$(P)$(R)GetIG")
    field(DESC, "Get Alphatross Ion Gauge Value")
    field(DTYP, "stream")
    field(INP,  "@devswag6.proto getResistance(10,0.1,(@5012)) $(PORT) $(A)")
After starting the ioc, I can do ' dbtr swag6testGetIG`, which sends the correct string, and gets a reply from the mainframe.  What I'm stuck on is handing the reply.  The box replies with:
 +9.90000000E+37\n
But the way I have things configured I get:
2023/01/24 12:49:07.000698 LAN0 swag6testGetIG: Format "%E" has data type double which is not supported by "swag6testGetIG".
It seems like that should work, based on: https://paulscherrerinstitute.github.io/StreamDevice/formats.html
I don't know if I managed to compile StreamDevice with some missing library, or if I've done something else wrong along the way.
Thanks for any pointers,
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
leblanc at ohio.edu
M: (401) 52-OUAL1 or (401) 526-8251
Re: Keysight 34980A SCPI StreamDevice Andrew Johnson via Tech-talk
Prev: Multiple job opportunities at Fermilab Accelerator Controls Denise S Finstrom via Tech-talk
Next: Re: Keysight 34980A SCPI StreamDevice Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 24 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
