Hi Yuliang
that was a typo in my mail.
Regards
Jörn
Am Dienstag, 31. Januar 2023, 14:10:41 CET schrieb Zhang Yuliang:
> Hi Jörn,
> I noticed that
> org.phoebus.pv.ca/max_array_bytes=400000000
> while
> EPICS_CA_MAX_ARRAY_BYTES = 40000000
> Regards,
> Yuliang
> -----原始邮件-----
> 发件人:"Jörn Dreyer via Tech-talk" <tech-talk at aps.anl.gov>
> 发送时间:2023-01-31 19:33:34 (星期二)
> 收件人: tech-talk at aps.anl.gov
> 抄送:
> 主题: Data transport problem with CA
> Hi,
> I run into a problem with transporting the data of an areaDetector image
> over CA. It works in one case, but not the other.
> I have one IOC that reads out three cameras
> 1) Two basler cameras with 659*494 pixels
> 2) One ASI 1600MM with 4656 x 3520 pixels
> Now to the problem:
> The Basler cameras do not make any problem, only the ASI1600MM is affected:
> It works in Phoebus when setting org.phoebus.pv.ca/max_array_bytes=400000000
> I can see reasonable Data when calling caget with a low number of elements
> to read, but fails with a warning "virtual circuit disconnect" when
> attempting to read the full image and all data is shown to be 0.
> The first lines of caget output are:
> caget imagePV:ArrayData
> Read operation timed out: some PV data was not read.
> imagePV:ArrayData 16389120 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> Limiting the amount of data read:
> caget imagePV:ArrayData -# 100
> imagePV:ArrayData 100 3520 3888 4080 4480 4560 4992 4480 4864 5136 5184 5536
> 6096 5488 4672 3024 2192 1536 1264 848 944 816 608 560 640 480 496 464 432
> 544 416 336 400 336 33 6 464 320 400 480 352 304 336 256 304 272 240 320
> 272 288 272 288 256 320 256 304 240 224 304 288 240 240 256 256 288 320 288
> 304 256 304 272 256 240 288 256 352 304 320 304 304 288 304 256 288 28 8
> 320 352 336 368 368 304 320 288 352 336 288 304 320 272 224 272 256
> The environment vaiable EPICS_CA_MAX_ARRAY_BYTES is set to 40000000 to match
> the setting for phoebus.
> What setting might need to be changed to get that working?
> Regards,
> Jörn
- Data transport problem with CA Jörn Dreyer via Tech-talk
- Re: Data transport problem with CA Zhang Yuliang via Tech-talk
Re: Data transport problem with CA Hu, Yong via Tech-talk
Re: Data transport problem with CA Jörn Dreyer via Tech-talk
<2023>
<2023>
