HI Yong,
Am Dienstag, 31. Januar 2023, 14:17:17 CET schrieb Hu, Yong:
> Hi Jörn,
> Firstly you missed one ‘0’ in your caget’s EPICS_CA_MAX_ARRAY_BYTES which is
> 40MB (not 400MB as you configured in Phoebus).
Thar difference was a typo in my mail.
> Having said that, 40MB should be enough for the ASI1600MM if your
> ‘imagePV:ArrayData’ is 16-bit data type: 4656*3520*2 = 32778240 < 40MB.
> What is your settings for the data type ‘imagePV:ArrayData’’? 16-bit,
> 24-bit, 32-bit?
The datatype is UINT16.
> Also, it is worth checking the settings of EPICS_CA_MAX_ARRAY_BYTES inside
> your IOC (i.e. st.cmd). I guess it is big enough, otherwise you will have
> trouble with the Phoebus reading. Anyway, what is the number you used for
> the ASI1600MM IOC?
EPICS_CA_MAX_ARRAY_BYTES=500000000
Jörn
> Cheers,
> Yong
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jörn Dreyer via
> Tech-talk <tech-talk at aps.anl.gov> Date: Tuesday, January 31, 2023 at 6:33
> AM
> To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> Subject: Data transport problem with CA
> Hi,
> I run into a problem with transporting the data of an areaDetector image
> over CA. It works in one case, but not the other.
> I have one IOC that reads out three cameras
> 1) Two basler cameras with 659*494 pixels
> 2) One ASI 1600MM with 4656 x 3520 pixels
> Now to the problem:
> The Basler cameras do not make any problem, only the ASI1600MM is affected:
> It works in Phoebus when setting org.phoebus.pv.ca/max_array_bytes=400000000
> I can see reasonable Data when calling caget with a low number of elements
> to read, but fails with a warning "virtual circuit disconnect" when
> attempting to read the full image and all data is shown to be 0.
> The first lines of caget output are:
> caget imagePV:ArrayData
> Read operation timed out: some PV data was not read.
> imagePV:ArrayData 16389120 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> Limiting the amount of data read:
> caget imagePV:ArrayData -# 100
> imagePV:ArrayData 100 3520 3888 4080 4480 4560 4992 4480 4864 5136 5184 5536
> 6096 5488 4672 3024 2192 1536 1264 848 944 816 608 560 640 480 496 464 432
> 544 416 336 400 336 33 6 464 320 400 480 352 304 336 256 304 272 240 320
> 272 288 272 288 256 320 256 304 240 224 304 288 240 240 256 256 288 320 288
> 304 256 304 272 256 240 288 256 352 304 320 304 304 288 304 256 288 28 8
> 320 352 336 368 368 304 320 288 352 336 288 304 320 272 224 272 256
> The environment vaiable EPICS_CA_MAX_ARRAY_BYTES is set to 40000000 to match
> the setting for phoebus.
> What setting might need to be changed to get that working?
> Regards,
> Jörn
- Re: Data transport problem with CA Mark Rivers via Tech-talk
- Data transport problem with CA Jörn Dreyer via Tech-talk
- Re: Data transport problem with CA Hu, Yong via Tech-talk
Re: Data transport problem with CA Jörn Dreyer via Tech-talk
<2023>
2025
<2023>
2025
