Hi folks, I'm starting to look at p4p and following this guide https://mdavidsaver.github.io/p4p/starting.html#starting. I'm running into this error. ImportError: libpvxs.so.1.1: cannot open shared object file: No such file or directory pip show pvxslibs shows it's installed. Full output below. But further inspection looks like only the info directory is installed. (p4ptest) [mrippa@localhost p4p2]$ ls -ltra /home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages total 40 drwxr-xr-x. 3 mrippa mrippa 4096 Jan 31 23:19 .. drwxr-xr-x. 2 mrippa mrippa 4096 Jan 31 23:29 numpy.libs drwxr-xr-x. 21 mrippa mrippa 4096 Jan 31 23:29 numpy drwxr-xr-x. 2 mrippa mrippa 4096 Jan 31 23:29 numpy-1.24.1.dist-info drwxr-xr-x. 9 mrippa mrippa 4096 Jan 31 23:29 epicscorelibs drwxr-xr-x. 2 mrippa mrippa 4096 Jan 31 23:29 epicscorelibs-7.0.7.99.0.0.dist-info drwxr-xr-x. 2 mrippa mrippa 4096 Jan 31 23:29 pvxslibs-1.1.1.dist-info drwxr-xr-x. 10 mrippa mrippa 4096 Jan 31 23:44 . drwxr-xr-x. 8 mrippa mrippa 4096 Jan 31 23:44 p4p drwxr-xr-x. 2 mrippa mrippa 4096 Jan 31 23:44 p4p-4.1.5.dist-info I tried to uninstall and reinstall with the same result. Tried on Fedora 37 and Rocky8 with the same result. $ uname -a Linux localhost.localdomain 6.1.8-200.fc37.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Jan 24 20:32:16 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux $ python -V Python 3.11.1 Thanks for any insight! -Matt (p4ptest) [mrippa@localhost p4p2]$ python -m pip install -U p4p nose2
Requirement already satisfied: p4p in ./p4ptest/lib64/python3.11/site-packages (4.1.5) Requirement already satisfied: nose2 in ./p4ptest/lib/python3.11/site-packages (0.12.0) Requirement already satisfied: epicscorelibs<7.0.7.99.1,>=7.0.7.99.0.0 in ./p4ptest/lib64/python3.11/site-packages (from p4p) (7.0.7.99.0.0) Requirement already satisfied: pvxslibs<1.2.0a1,>=1.1.1 in ./p4ptest/lib64/python3.11/site-packages (from p4p) (1.1.1) Requirement already satisfied: numpy>=1.24.1 in ./p4ptest/lib64/python3.11/site-packages (from p4p) (1.24.1) Requirement already satisfied: ply in ./p4ptest/lib/python3.11/site-packages (from p4p) (3.11) Requirement already satisfied: setuptools in ./p4ptest/lib/python3.11/site-packages (from epicscorelibs<7.0.7.99.1,>=7.0.7.99.0.0->p4p) (65.6.3) Requirement already satisfied: setuptools-dso>=2.0a1 in ./p4ptest/lib/python3.11/site-packages (from epicscorelibs<7.0.7.99.1,>=7.0.7.99.0.0->p4p) (2.6) (p4ptest) [mrippa@localhost p4p2]$ python -m nose2 p4p
E ====================================================================== ERROR: p4p (nose2.loader.LoadTestsFailure.p4p) ---------------------------------------------------------------------- Traceback (most recent call last): File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/_vendor/six.py", line 719, in reraise raise value File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/plugins/loader/functions.py", line 81, in loadTestsFromName result = util.test_from_name(name, module) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/util.py", line 92, in test_from_name parent, obj = object_from_name(name, module) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/util.py", line 112, in object_from_name (module, import_error) = try_import_module_from_name(parts[:]) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/util.py", line 171, in try_import_module_from_name six.reraise(*import_error) File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/_vendor/six.py", line 719, in reraise raise value File "/home/mrippa/work/p4p2/p4ptest/lib/python3.11/site-packages/nose2/util.py", line 165, in try_import_module_from_name module = __import__(".".join(splitted_name)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages/p4p/__init__.py", line 14, in <module> from .wrapper import Value, Type File "/home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages/p4p/wrapper.py", line 5, in <module> from . import _p4p ImportError: libpvxs.so.1.1: cannot open shared object file: No such file or directory ---------------------------------------------------------------------- Ran 1 test in 0.000s FAILED (errors=1) (p4ptest) [mrippa@localhost p4p2]$ pip show pvxslibs Name: pvxslibs
Version: 1.1.1 Summary: PVXS libraries packaged for python Home-page: https://mdavidsaver.github.io/pvxs Author: Michael Davidsaver Author-email: mdavidsaver at gmail.com License: BSD Location: /home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages Requires: epicscorelibs, setuptools-dso Required-by: p4p (p4ptest) [mrippa@localhost p4p2]$ python -m p4p.server.cli my:pv:name=int
Traceback (most recent call last): File "<frozen runpy>", line 189, in _run_module_as_main File "<frozen runpy>", line 112, in _get_module_details File "/home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages/p4p/__init__.py", line 14, in <module> from .wrapper import Value, Type File "/home/mrippa/work/p4p2/p4ptest/lib64/python3.11/site-packages/p4p/wrapper.py", line 5, in <module> from . import _p4p ImportError: libpvxs.so.1.1: cannot open shared object file: No such file or directory
ANJ, 08 Feb 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
