Here's the Fedora 37, Python 3.11 output. Cheers, -Matt [mrippa@localhost p4p]$ python -m virtualenv p311env created virtual environment CPython3.11.1.final.0-64 in 104ms creator CPython3Posix(dest=/home/mrippa/work/p4p/p311env, clear=False, no_vcs_ignore=False, global=False) seeder FromAppData(download=False, pip=bundle, setuptools=bundle, wheel=bundle, via=copy, app_data_dir=/home/mrippa/.local/share/virtualenv) added seed packages: pip==22.3.1, setuptools==65.6.3, wheel==0.38.4 activators BashActivator,CShellActivator,FishActivator,NushellActivator,PowerShellActivator,PythonActivator [mrippa@localhost p4p]$ [mrippa@localhost p4p]$ [mrippa@localhost p4p]$ . p311env/bin/activate (p311env) [mrippa@localhost p4p]$ python -m pip install -U pip Requirement already satisfied: pip in ./p311env/lib/python3.11/site-packages (22.3.1) Collecting pip Using cached pip-23.0-py3-none-any.whl (2.1 MB) Installing collected packages: pip Attempting uninstall: pip Found existing installation: pip 22.3.1 Uninstalling pip-22.3.1: Successfully uninstalled pip-22.3.1 Successfully installed pip-23.0 (p311env) [mrippa@localhost p4p]$ python -m pip install nose2 Collecting nose2 Using cached nose2-0.12.0-py2.py3-none-any.whl (152 kB) Installing collected packages: nose2 Successfully installed nose2-0.12.0 (p311env) [mrippa@localhost p4p]$ python -m pip install -v p4p Using pip 23.0 from /home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/pip (python 3.11) Collecting p4p Using cached p4p-4.1.5-cp311-cp311-linux_x86_64.whl Collecting epicscorelibs<7.0.7.99.1,>=7.0.7.99.0.0 Using cached epicscorelibs-7.0.7.99.0.0-cp311-cp311-linux_x86_64.whl Collecting pvxslibs<1.2.0a1,>=1.1.1 Using cached pvxslibs-1.1.1-cp311-cp311-linux_x86_64.whl Link requires a different Python (3.11.1 not in: '>=3.7,<3.11'): https://files.pythonhosted.org/packages/3a/be/650f9c091ef71cb01d735775d554e068752d3ff63d7943b26316dc401749/numpy-1.21.2.zip (from https://pypi.org/simple/numpy/) (requires-python:>=3.7,<3.11) Link requires a different Python (3.11.1 not in: '>=3.7,<3.11'): https://files.pythonhosted.org/packages/5f/d6/ad58ded26556eaeaa8c971e08b6466f17c4ac4d786cd3d800e26ce59cc01/numpy-1.21.3.zip (from https://pypi.org/simple/numpy/) (requires-python:>=3.7,<3.11) Link requires a different Python (3.11.1 not in: '>=3.7,<3.11'): https://files.pythonhosted.org/packages/fb/48/b0708ebd7718a8933f0d3937513ef8ef2f4f04529f1f66ca86d873043921/numpy-1.21.4.zip (from https://pypi.org/simple/numpy/) (requires-python:>=3.7,<3.11) Link requires a different Python (3.11.1 not in: '>=3.7,<3.11'): https://files.pythonhosted.org/packages/c2/a8/a924a09492bdfee8c2ec3094d0a13f2799800b4fdc9c890738aeeb12c72e/numpy-1.21.5.zip (from https://pypi.org/simple/numpy/) (requires-python:>=3.7,<3.11) Link requires a different Python (3.11.1 not in: '>=3.7,<3.11'): https://files.pythonhosted.org/packages/45/b7/de7b8e67f2232c26af57c205aaad29fe17754f793404f59c8a730c7a191a/numpy-1.21.6.zip (from https://pypi.org/simple/numpy/) (requires-python:>=3.7,<3.11) Collecting numpy>=1.24.1 Using cached numpy-1.24.1-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (17.3 MB) Requirement already satisfied: nose2>=0.8.0 in ./p311env/lib/python3.11/site-packages (from p4p) (0.12.0) Collecting ply Using cached ply-3.11-py2.py3-none-any.whl (49 kB) Requirement already satisfied: setuptools in ./p311env/lib/python3.11/site-packages (from epicscorelibs<7.0.7.99.1,>=7.0.7.99.0.0->p4p) (65.6.3) Collecting setuptools-dso>=2.0a1 Using cached setuptools_dso-2.6-py2.py3-none-any.whl (20 kB) Installing collected packages: ply, setuptools-dso, numpy, epicscorelibs, pvxslibs, p4p changing mode of /home/mrippa/work/p4p/p311env/bin/f2py to 755 changing mode of /home/mrippa/work/p4p/p311env/bin/f2py3 to 755 changing mode of /home/mrippa/work/p4p/p311env/bin/f2py3.11 to 755 changing mode of /home/mrippa/work/p4p/p311env/bin/pvagw to 755 Successfully installed epicscorelibs-7.0.7.99.0.0 numpy-1.24.1 p4p-4.1.5 ply-3.11 pvxslibs-1.1.1 setuptools-dso-2.6 (p311env) [mrippa@localhost p4p]$ python -m nose2 p4p E ====================================================================== ERROR: p4p (nose2.loader.LoadTestsFailure.p4p) ---------------------------------------------------------------------- Traceback (most recent call last): File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/_vendor/six.py", line 719, in reraise raise value File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/plugins/loader/functions.py", line 81, in loadTestsFromName result = util.test_from_name(name, module) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/util.py", line 92, in test_from_name parent, obj = object_from_name(name, module) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/util.py", line 112, in object_from_name (module, import_error) = try_import_module_from_name(parts[:]) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/util.py", line 171, in try_import_module_from_name six.reraise(*import_error) File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/_vendor/six.py", line 719, in reraise raise value File "/home/mrippa/work/p4p/p311env/lib/python3.11/site-packages/nose2/util.py", line 165, in try_import_module_from_name module = __import__(".".join(splitted_name)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mrippa/work/p4p/p311env/lib64/python3.11/site-packages/p4p/__init__.py", line 14, in <module> from .wrapper import Value, Type File "/home/mrippa/work/p4p/p311env/lib64/python3.11/site-packages/p4p/wrapper.py", line 5, in <module> from . import _p4p ImportError: libpvxs.so.1.1: cannot open shared object file: No such file or directory ---------------------------------------------------------------------- Ran 1 test in 0.000s FAILED (errors=1) On Wed, Feb 1, 2023 at 6:09 PM Matt Rippa <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
