1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: [EXTERNAL] Re: looking for a spec for the MRF timing protocol
To: "Evans, Richard K. (GRC-H000)" <[email protected]>, Jukka Pietarinen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Feb 2023 10:50:19 +0000
Just two cents from our side:
	Can 3rd parties develop I/O devices that interact with the MRF timing system?
Yes. We have been doing such devices (receiver and extension modules) in Cosylab with collaboration with MRF for several years now and we covered multiple form factors. We did it either in EPICS or in LabVIEW, though some other framework could be also done.
Some of the devices that have been created as a result of this collaboration include:
-	A timing receiver and generator card designed to fit the PXIe form factor, making it compatible with National Instruments crates.
-	The IFB300, an external I/O expansion box that can accommodate up to eight I/O modules, providing an efficient and scalable solution for expanding I/O capabilities.
-	A universal IO module with two 32 Mbps RS-485 transmitters and RJ-45 connector, used for triggering a RF injector.
-	Universal IO module with two LVTTL/TTL outputs with superior protection against overvoltage events and selectable output level (3.3 or 5 V) and selectable output termination.
In addition to these, Cosylab has also created custom timing systems using MRF hardware. These custom systems have undergone a complete FPGA firmware redesign and implementation and have been customized for several clients to support special modes of operation, such as multiple parallel sequence execution slots and downstream and upstream event and data transfer.
If you need help with any custom implementation, feel free to contact us.
Best regards,
Žiga
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Evans,
> Richard K. (GRC-H000) via Tech-talk
> Sent: petek, 03. februar 2023 15:15
> To: Jukka Pietarinen <[email protected]>; Timo Korhonen
> <[email protected]>; Guobao Shen <[email protected]>; tech-
> [email protected]
> Cc: Evans, Richard K. (GRC-H000) <[email protected]>
> Caution: This email originated from outside of Cosylab.
> Jukka, Timo, Di, and Guobao, for the insights and links. This is all very helpful,
> especially the open-source EVR design and the DCManual-191127.pdf.
> Truest thanks!
> /Rich
looking for a spec for the MRF timing protocol Evans, Richard K. (GRC-H000) via Tech-talk
Re: looking for a spec for the MRF timing protocol Shen, Guobao via Tech-talk
RE: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Evans, Richard K. (GRC-H000) via Tech-talk
Re: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Shen, Guobao via Tech-talk
Re: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Timo Korhonen via Tech-talk
Re: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Jukka Pietarinen via Tech-talk
Prev: RE: Problems using Universal I/O GAGET Alexis via Tech-talk
Next: Re: Quickstart Error trying P4P Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Evans, Richard K. (GRC-H000) via Tech-talk
Next: Re: [EXTERNAL] Re: looking for a spec for the MRF timing protocol Di Wang via Tech-talk
