Hi GY, Too late, but I can spend a little time finally. On Thu, Jan 5, 2023 at 11:15 PM 문건영(선형가속기팀) <gymun at postech.ac.kr> wrote:
Because that document was generated after manually updating the local pciid file. Please see the repository After leaving my previous company, I archived it and didn't updated my pciid file from the latest pciid file. I resume the repo, and merge the latest pciid into the repository. Please check the REAME file. I only test it with Debian11 without any MRF hardware. After you update your local pciid file with the repository one, you can see the mrf hardware name by executing "lspci." Note that now 7011 was defined now officially, so I removed my description of that definition. In addition, my old and stand-alone script https://github.com/icshwi/e3-mrfioc2/blob/master/tools/get_pciaddr.bash may help you get some information also.
Once you plug them into the MTCA chassis, you should know where you plug them in. In addition, you have to configure them seriously within MCH. Sometimes, you have to configure the MTCA backplane settings into MCH. All information must be defined first when configuring your MCH for the clock distribution according to your system configuration. Only the fixed static configuration you have. So, you'll need to know all static information of your timing hardware before IOC implementation. The one repository and the script I share may help you to define all static information. HTH, Han
-- Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163 Cell:+1-510-384-3868
ANJ, 12 Feb 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
