1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Alarm Logger Display
From: William F Badgett Jr via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Shroff, Kunal" <shroffk at bnl.gov>
Date: Thu, 23 Feb 2023 17:22:13 +0000
Hello,
In the Phoebus alarm logger query class:
org.phoebus.applications.alarm.logging.ui.AlarmLogSearchJob
the query appears to be constructed at line 85:
            String resultStr =  client.path("/search/alarm")
                    .queryParams(map)
                    .accept(MediaType.APPLICATION_JSON).get(String.class);
The "/search/alarm" URL syntax does not appear to match the current syntax of the Alarm Logger, which partitions data by month and by Kafka topic.
Is my understanding correct?  If yes, can this be fixed?  If not, what am I doing wrong?
thanks
William Badgett
Accelerator Division Controls
Neutrino Division Operations
Fermi National Accelerator Lab
Kirk and Wilson Roads
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
badgett at fnal.gov
Prev: RE: Using asyn as a TCP socket client in AD ioc Mark Rivers via Tech-talk
Next: Re: Using asyn as a TCP socket client in AD ioc Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Using asyn as a TCP socket client in AD ioc Marco A. Barra Montevechi Filho via Tech-talk
Next: Support with EPICS-based applications Chitra Venkataraman via Tech-talk
ANJ, 24 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
