1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Periodic scan Issue with PV record scan type as IO Intr
From: Arnab Dasgupta via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Fri, 24 Feb 2023 17:42:59 +0530 (IST)
I am facing issue in archiving the PV using the EPICS archiver appliance with periodic scan. The issue I found is when the PV record scan type is periodic then the PV is archived properly, But when the PV  record scan type is either I/O Intr or passive the archiver appliance does not archive data periodically using scan method (Screenshot attached for reference). Is there a workaround for this?
Please suggest and help resolving this issue.
Thanks
Arnab
Attachment: scan periodic.png
Description: PNG image
Attachment: scan io intr.png
Prev: AreaDetector, order of DetectorState_RBV and AcquireBusy Sebastian Eckert via Tech-talk
Next: RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
Next: mvme6100 maxv controller maxvsetup whitetiger1123 via Tech-talk
