1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Appending to existing records
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: Andrew Johnson <[email protected]>, Simon Rose <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Mar 2023 10:28:15 +0000
Hi Andrew, Simon,
Thanks, this works perfectly.
Tom
Sent: 10 March 2023 10:25
To: Simon Rose <[email protected]>; Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>; [email protected] <[email protected]>
Asterisk ('*') is not actually a valid bare-word string character:
Cox$ bin/darwin-aarch64/softIoc -d ~/db/star.db
Error: Invalid character '*'
 at or before '*' in file "/Users/anj/db/
star.db" line 2
Error: syntax error
dbLoadRecords: failed to load '/Users/anj/db/
star.db'
Error: Failed to load: /Users/anj/db/
star.db
You have to enclose it in double quotes, but Simon's response is otherwise correct, this works:
Cox$ cat ~/db/star.db
record(ai, "ai") { }
record("*", "ai") { }
- Andrew
On 3/10/23 10:14 AM, Simon Rose via Tech-talk wrote:
Hi Tom –
You can use
record(*, “MYRECORD”)
for that purpose.
Cheers,
Simon
From: Tech-talk <[email protected]> on behalf of "Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk" <[email protected]>
Reply to: "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Friday, 10 March 2023 at 11:09
Subject: Appending to existing records
Hi all,
To avoid modifying upstream database templates, I would like to make a second template that appends to the existing records:
$ cat upstream.template
record(ai, "MYRECORD") {
  field(VAL, "1")
$ cat local.template
include "upstream.template"
  info(archive, "VAL")
It would be nice to not have to repeat the type of the record in the second file. Is this possible? If not, could we add an "overload" or "existing" record type to they syntax that would allow this?
Tom
Complexity comes for free, Simplicity you have to work for.
Appending to existing records Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Appending to existing records Simon Rose via Tech-talk
Re: Appending to existing records Andrew Johnson via Tech-talk
Prev: Re: Appending to existing records Andrew Johnson via Tech-talk
Next: Re: Periodic SCAN issue in EPICS Archiver Appliance Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Using subArray record Marco A. Barra Montevechi Filho via Tech-talk
