1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: External: Where the antelope play?
To: William F Badgett Jr <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 16 Mar 2023 21:42:22 +0000
Hi William
I exclusively build in docker containers and those are the steps that install the packages for Alma 9.1.
-- snip ------------------------------------------
FROM almalinux:9.1 AS base
ARG epicsBaseVersion
# ===== Metadata
LABEL ca.lightsource="Canadian Light Source Inc."
LABEL ca.lightsource.image.authors="[email protected]"
LABEL version="1.3.1"
LABEL description="CLS Docker image for EPICS R7.0.7, OS: AlmaLinux 9.1"
ENV EPICS_HOST_ARCH=Alma9-x86_64
RUN dnf -y update
RUN dnf -y groupinstall 'Development Tools'
RUN dnf -y install vim tree perl
RUN dnf -y install readline-devel ncurses-devel libcurl-devel
# needed for asyn
RUN dnf -y --enablerepo=crb install libtirpc-devel
# needed for edm
RUN dnf -y install motif motif-devel libXtst-devel
RUN dnf -y --enablerepo=crb install giflib-devel
# ----- cleanup
RUN dnf clean all
CONFIG.Common has
COMMANDLINE_LIBRARY = READLINE_NCURSES
That's all I needed to compile w/o errors.
HTH
Niko
Dr. Niko Kivel, CSPO
Senior Controls Analyst | Canadian Light Source
+1-306-657-3778
lightsource.ca
From: Tech-talk <[email protected]> on behalf of William F Badgett Jr via Tech-talk <[email protected]>
Sent: Thursday, March 16, 2023 3:00:19 PM
To: [email protected]
Subject: External: Where the antelope play?
Looks like antelope compiling has been a recurring problem over the years for EPICS base, I tried each of the suggestions without improvement:
EPICS_HOST_ARCH=linux-x86_64
on AlmaLinux 9
make[4]: *** No rule to make target 'antelope', needed by '../../../../bin/linux-x86_64/antelope'.  Stop.
make[4]: Leaving directory '/data/base-7.0.7/modules/libcom/src/O.linux-x86_64'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[3]: Leaving directory '/data/base-7.0.7/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/data/base-7.0.7/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory '/data/base-7.0.7/modules'
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
Things tried:
  1. installed various ncurses packages
  2. Played with CONFIG_SITE.Common.linux-x86_64, various curses, ncurses and related options
Any ideas?
thanks
William Badgett
Accelerator Division Controls
Neutrino Division Operations
Fermi National Accelerator Lab
Kirk and Wilson Roads
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
Where the antelope play? William F Badgett Jr via Tech-talk
Prev: Where the antelope play? William F Badgett Jr via Tech-talk
Next: Re: Where the antelope play? Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
