Hi Di Wang,
On vxWorks you can also use the iocsh shell, and then you can run the same "help" commands that you run on other operating systems.
At the vxWorks prompt type:
iocsh
You will then be in the iocsh shell.
To return to the vxWorks shell type "exit".
You can also run iocsh in your st.cmd.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Di Wang via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 17, 2023 2:48 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: The help command for VxWorks shell
Hello all,
I always use `help pattern⋆` command on iocsh to list and search iocsh
commands, but this does not work on the VxWorks shell.
The `lkup` command provided by VxWorks will search all symbols and is
sometimes not very convenient. So I am wondering is there any similar
method on VxWorks shell to list and search all registered ioc commands?
Cheers,
Di Wang
- Re: The help command for VxWorks shell Di Wang via Tech-talk
- The help command for VxWorks shell Di Wang via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 17 Mar 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
