1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: The help command for VxWorks shell
To: [email protected]
Date: Fri, 17 Mar 2023 21:26:39 +0900
Hi Mark,
Pretty nice solution! Thanks a lot.
cheers
Di Wang
On 2023/03/17 21:14, Mark Rivers wrote:
Hi Di Wang,
On vxWorks you can also use the iocsh shell, and then you can run the same "help" commands that you run on other operating systems.
At the vxWorks prompt type:
iocsh
You will then be in the iocsh shell.
To return to the vxWorks shell type "exit".
You can also run iocsh in your st.cmd.
*From:* Tech-talk <[email protected]> on behalf of Di Wang via Tech-talk <[email protected]>
*Sent:* Friday, March 17, 2023 2:48 AM
*To:* [email protected] <[email protected]>
*Subject:* The help command for VxWorks shell
Hello all,
I always use `help pattern⋆` command on iocsh to list and search iocsh
commands, but this does not work on the VxWorks shell.
The `lkup` command provided by VxWorks will search all symbols and is
sometimes not very convenient. So I am wondering is there any similar
method on VxWorks shell to list and search all registered ioc commands?
Cheers,
Di Wang
The help command for VxWorks shell Di Wang via Tech-talk
Re: The help command for VxWorks shell Mark Rivers via Tech-talk
Prev: Re: The help command for VxWorks shell Mark Rivers via Tech-talk
Next: Re: About MAXv controller PV recognize problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: using macros in Action, Execute Command Paul Sichta via Tech-talk
