Using phoebus, I used an action button and added an Execute Command. My macro will not work when used in the Command line. The macro will work in action type WritePV, or as a PVname for an object on the display.
Example: I add to my environment before starting phoebus, export myLS=ls In the action command line I use $(myLS) When I run the action I get an error Cannot run program "$myLS" (in directory blah...); error=2, No such file or directory If I simply use ls in the command it works fine. The help, about, inspect environmental variables it shows: myLS = ls Is there a way to use macros from the user's environment on these Execute Commands? In particular, I want to use a macro to be a directory path on my system Regards, -ps
ANJ, 20 Mar 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
