Thanks Michael! With the update, the .json file worked and I have my groups up and running. Best regards, Ignacio
On 3/15/23 16:50, Ignacio Arriagada via Tech-talk wrote:
> Hello everyone,
> I'm trying to configure a PVA group using a json file, but I get the following error:
> *synch:Page1: Error Group not created: NULL channel
> synch:Page2: Error Group not created: NULL channel*
> The group is defined in *cemSoftIoc.json* as follows:
...> And the database is defined in *cemSoftIoc.db* as follows:
> If I define the same groups within the database using the q:group definition it works without issues. But trying the json definition, it fails because of a null channel.
I suspect that this issue is fixed by a change to the pva2pva module
which has not yet been released. With it, I am able to load a
modified version of cemSoftIoc.db (change genSub -> aSub, remove
UF* fields) and cemSoftIoc.json.
https://github.com/epics-base/pva2pva/commit/db5af06e07b726b17422413a8176201d3687bdf9
> $ softIocPVA -m top=synch: -d cemSoftIoc.db -G cemSoftIoc.json
> Starting iocInit
> ## EPICS R7.0.7.1-DEV
> ## Rev. R7.0.7-128-g6399af2037deb2b75eb8-dirty
> ## Rev. Date Git: 2023-03-12 09:15:10 +0000
> recGblRecordError: aSubRecord::init_record - SNAM subr not found Subroutine not found PV: synch:CmplxData
> iocRun: All initialization complete
> epics> dbgl
> synch:Page1
> synch:Page2
> epics>
- Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
- Re: Problem with PVA group def using .json file Michael Davidsaver via Tech-talk
using macros in Action, Execute Command Paul Sichta via Tech-talk
<2023>
2025
2026
Where the antelope play? William F Badgett Jr via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
