1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Problem with PVA group def using .json file
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Ignacio Arriagada <[email protected]>
Cc: [email protected]
Date: Fri, 17 Mar 2023 08:35:15 -0700
On 3/15/23 16:50, Ignacio Arriagada via Tech-talk wrote:
Hello everyone,
I'm trying to configure a PVA group using a json file, but I get the following error:
*synch:Page1: Error Group not created: NULL channel
synch:Page2: Error Group not created: NULL channel*
The group is defined in *cemSoftIoc.json* as follows:
...> And the database is defined in *cemSoftIoc.db* as follows:
If I define the same groups within the database using the q:group definition it works without issues. But trying the json definition, it fails because of a null channel.
I suspect that this issue is fixed by a change to the pva2pva module
which has not yet been released.  With it, I am able to load a
modified version of cemSoftIoc.db  (change genSub -> aSub, remove
UF* fields) and cemSoftIoc.json.
https://github.com/epics-base/pva2pva/commit/db5af06e07b726b17422413a8176201d3687bdf9
$ softIocPVA -m top=synch: -d cemSoftIoc.db -G cemSoftIoc.json Starting iocInit
## EPICS R7.0.7.1-DEV
## Rev. R7.0.7-128-g6399af2037deb2b75eb8-dirty
## Rev. Date Git: 2023-03-12 09:15:10 +0000
recGblRecordError: aSubRecord::init_record - SNAM subr not found Subroutine not found PV: synch:CmplxData
epics> dbgl
synch:Page1
synch:Page2
epics>
Re: Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
Prev: Re: About MAXv controller PV recognize problem Mark Rivers via Tech-talk
Next: Re: Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
