1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: [EXTERNAL] Fwd: MongoDB Implementation using EPICS 7
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, "Jemian, Pete R." <[email protected]>
Date: Thu, 23 Mar 2023 13:42:24 +0000
Hi:
> One could think of using MongoDB as a backend for an EPICS archiver (which records time series of the configured PVs) but there are better backends to choose for such time-series data.
I briefly looked into that many years ago.
MongoDB allows storing arbitrary data. Each "value" can be a different JSON-type structure. For archived data, I didn't see a huge benefit because we do have structured data. Each sample is basically a time stamp and a value, then millions of those. OK, different PVs might have slightly different data types, but I don't need to store a sequence of random structures. That was before PV Access. With PV Access, you might argue that you do want to store arbitrary structures, but then you also need to decode these with custom clients to make sense of the data. So I'd say the main use case for an archive is still a large number of timestamp + value.
When I then compared MongoDB storing many samples with timestamp, value(, alarm info) against MySQL using a plain table of timestamp, value, alarm info, performance was roughly the same, so I stopped it there.
Cheers,
Kay
Fwd: MongoDB Implementation using EPICS 7 Pete Jemian via Tech-talk
Prev: Re: Differences between using disconnectOnReadTime in asynSetOption and asyn record Mark Rivers via Tech-talk
Next: RE: Differences between using disconnectOnReadTime in asynSetOption and asyn record Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Fwd: MongoDB Implementation using EPICS 7 Pete Jemian via Tech-talk
Next: EPICS Support for variable frequency motor drivers? Ralph Lange via Tech-talk
