Hi Enrico,
I think what you are seeing is the expected behavior. The INVALID/UDF means that the record has not been processed. Consider the case where your record is being used to write those values to hardware. The UDF is a warning that because the record has not processed then the hardware may not be consistent with the record value.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Érico Nogueira Rolim via Tech-talk
Sent: Thursday, March 23, 2023 3:18 PM
To: [email protected]
Subject: Does using "Constant Link Values" require using PINI=YES?
Hello!
I am using Constant Link Values, as documented in [1], to initialize some waveforms in my IOC. I'm defining my records as shown below:
record(waveform, "Array-Cte"){
field(FTVL, "LONG")
field(NELM, "4")
field(INP, [1,2,3,4])
However, when I use camonitor or pvget to receive their values, I am notified that their values are, in fact, undefined/invalid:
$ pvget Array-Cte
Array-Cte <undefined> INVALID DRIVER UDF [1,2,3,4]
$ camonitor Array-Cte
Array-Cte <undefined> 4 1 2 3 4 UDF INVALID
If I add field(PINI, YES) to the record definition, I no longer get notified about invalid values or anything. But it feels wrong to have to add PINI in this case, since I'm declaring an initializer explicitly, and it also feels ugly to leave the UDF/INVALID text in the output. Is this expected behavior?
I am using epics-7 at the tip of master as of today (5eff3803a83fbc3ea855b63841f5359c09830ade). This happens for waveforms where FTVL is "STRING" as well, at the very least. It also happens if I use the "{const: [1,2,3,4]}" syntax from [2].
[1] https://epics.anl.gov/base/R3-16/1-docs/RELEASE_NOTES.html
[2] https://epics.anl.gov/base/R7-0/7-docs/links.html
Thank you,
Érico
P.S.: I couldn't find documentation that specified clearly that JSON links could be used in places like input links for "newer" EPICS releases, outside of the release notes. That might be an interesting hole to plug in the docs. Would it go somewhere like [3]? I could try to tackle it.
[3]
https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Does using "Constant Link Values" require using PINI=YES? Érico Nogueira Rolim via Tech-talk
BiRa EMCOR vs. PCRC (aka. EPSC)? Michael Davidsaver via Tech-talk
<2023>
2025
2026
Re: Does using "Constant Link Values" require using PINI=YES? Timo Korhonen via Tech-talk
<2023>
2025
2026
