1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Does using "Constant Link Values" require using PINI=YES?
From: Timo Korhonen via Tech-talk <[email protected]>
To: Érico Nogueira Rolim <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Mar 2023 10:00:19 +0000
Hi Érico,
>> P.S.: I couldn't find documentation that specified clearly that JSON links could be used in places like input links for "newer" EPICS
>> releases, outside of the release notes. That might be an interesting hole to plug in the docs. Would it go somewhere like [3]? I could try to
>> tackle it.
A good point, thank you for bringing this up.  The source file for [2] is in the Base distribution, modules/database/src/std/link/links.dbd.pod
in pod (Perl POD) format. In the build process, the document is auto-converted to HTML using some Perl scripts and libraries.
Even if the file has the .dbd.pod extension, it is pure documentation and contains no dbd definitions or such.
I see two alternatives:
1) as the text is rather "stable", i.e., has not and probably will not change a lot, integrating the text in [3], as you suggest.
2) I have an ambition to extend the build process a bit so that the pod file(s) would be processed and auto-included in RTD documentation, to be visible on docs.epics-controls.org.
However, option 2 has been progressing very slowly as my day job tends to take most of my time...
Integrating the description into [3] would make the usage clearer for users, so that might be the better (and right, IMO) option.
The document is written and "owned" by Andrew Johnson, so I think he has the decisive vote.
But if we go for option 1 and you are willing to do the editing, please give it a go and make a pull request. It would then go to the docs site after review and merge.
Please let me know if you need instructions on how to proceed.
Best regards,
Timo
On 2023-03-23, 21:18, "Tech-talk on behalf of Érico Nogueira Rolim via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hello!
I am using Constant Link Values, as documented in [1], to initialize
some waveforms in my IOC. I'm defining my records as shown below:
record(waveform, "Array-Cte"){
field(FTVL, "LONG")
field(NELM, "4")
field(INP, [1,2,3,4])
However, when I use camonitor or pvget to receive their values, I am
notified that their values are, in fact, undefined/invalid:
$ pvget Array-Cte
Array-Cte <undefined> INVALID DRIVER UDF [1,2,3,4]
$ camonitor Array-Cte
Array-Cte <undefined> 4 1 2 3 4 UDF INVALID
If I add field(PINI, YES) to the record definition, I no longer get
notified about invalid values or anything. But it feels wrong to have to
add PINI in this case, since I'm declaring an initializer explicitly,
and it also feels ugly to leave the UDF/INVALID text in the output. Is
this expected behavior?
I am using epics-7 at the tip of master as of today
(5eff3803a83fbc3ea855b63841f5359c09830ade). This happens for waveforms
where FTVL is "STRING" as well, at the very least. It also happens if I
use the "{const: [1,2,3,4]}" syntax from [2].
[1] https://epics.anl.gov/base/R3-16/1-docs/RELEASE_NOTES.html <https://epics.anl.gov/base/R3-16/1-docs/RELEASE_NOTES.html>
[2] https://epics.anl.gov/base/R7-0/7-docs/links.html <https://epics.anl.gov/base/R7-0/7-docs/links.html>
Thank you,
Érico
tackle it.
[3]
https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html <https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html>
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Does using "Constant Link Values" require using PINI=YES? Andrew Johnson via Tech-talk
Does using "Constant Link Values" require using PINI=YES? Érico Nogueira Rolim via Tech-talk
Prev: Job Opportunity BESSY II Smith, William via Tech-talk
Next: GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: Does using "Constant Link Values" require using PINI=YES? Mark Rivers via Tech-talk
Next: Re: Does using "Constant Link Values" require using PINI=YES? Andrew Johnson via Tech-talk
