1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: 回覆: Value of Renishaw absolute encoder exceeds its maximum
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>
Date: Fri, 24 Mar 2023 07:31:27 +0000
Hi, Torsten Bögershausen,
thanks for replying.
After examining the positions of encoder reader and scale,
it may be ok to adjust the position of the reader reader downward a little bit.
Best regards.
LiangChih Chiang
 NSRRC
 Beamline Group
 email:[email protected]
寄件者: Torsten Bögershausen <[email protected]>
寄件日期: 2023年3月24日 下午 12:59
收件者: Chiang, Liang-Chih [江良志] <[email protected]>
副本: [email protected] <[email protected]>
主旨: Re: Value of Renishaw absolute encoder exceeds its maximum
Hej LiangChih Chiang,
there is no good solution to handle this in software, as far as I know.
The best thing would be to talk out the encoder (mechanically),
rotate it by hand so that the value of the encoder at the negative
limit switch is close to zero, with  a little margin.
Say 1000 or so, as an example.
Put the encodet back into the mechanics, and verify that there is no
Overflow / wrap around through the whole driving range from
Low- to the high limit switch.
> On 24 Mar 2023, at 04:32, Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]> wrote:
> Hello,
> I use Galil DMC-4080 controller to read Renishaw absolute encoders(26 bits).
> So far so good.
> However, I conjectured that I encounter the situation where encoder's value
> exceeds its maximum(2^26 = 67,108,864).
> 66,000,166 is the encoder value initially.
> 59,829,149 when going to negative limit switch, which is ok.
> 899,833 when going to positive limit switch, which is abnormal.
> What could I do to handle this situation?
> 1.  Replace the encoder scale.
> 2.  Can I remedy it in EPICS? How? I have no idea.
> Best regards.
> LiangChih Chiang
> NSRRC
> Beamline Group
Value of Renishaw absolute encoder exceeds its maximum Chiang, Liang-Chih [江良志] via Tech-talk
Re: Value of Renishaw absolute encoder exceeds its maximum Torsten Bögershausen via Tech-talk
Prev: Re: Value of Renishaw absolute encoder exceeds its maximum Torsten Bögershausen via Tech-talk
Next: Re: Doubts about libpcre in compilation NICOLE Remi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Job Opportunity BESSY II Smith, William via Tech-talk
