Not sure about Ubuntu 22.04
The "older" Ubuntus may have needed this:
sudo apt-get install -y libmotif-dev x11proto-print-dev xfonts-100dpi libxmu-dev libxpm-dev
And may be this helps:
https://epics.anl.gov/tech-talk/2018/msg02175.php
<https://github.com/EuropeanSpallationSource/medm/commit/bc992f873433af58ad32a3d735c18c47821368f3>
/Torsten
If my problem is just because I overlooked some instructions, I apologize.
system: Ubuntu 22.04.2 LTS
epics base: epics-base-R7.0.7 (installed smoothly)
medm extensions: extensionsTop_20120904.tar.gz
medm: tried both 'medm-MEDM3_1_17' and current git clone
modifying made before medm/make: (1) set MOTIF_LIB and X11_LIB to /usr/lib/x86_64-linux-gnu in extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64, (2) in using 'USR_LIBS_Linux = Xm Xt Xmu X11 Xext' in medm/medm/Makefile (the
modifications made the compile go further).
Currently, the make error is (the ending part of make output):
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -Werror-implicit-function-declaration -DSCIPLOT -DMOTIF -DEDITRES -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc
-I../../../../include/os/Linux -I../../../../include -I/home/rong/EPICS/epics-base-R7.0.7/include/compiler/gcc -I/home/rong/EPICS/epics-base-R7.0.7/include/os/Linux -I/home/rong/EPICS/epics-base-R7.0.7/include -I../../printUtils -I../../xc -I/usr/include
-I/usr/include -c ../xgif.c
/usr/bin/g++ -o medm -L/home/rong/EPICS/extensions/lib/linux-x86_64 -L/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64 -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/home/rong/EPICS/extensions/lib/linux-x86_64 -Wl,-rpath,/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64
-Wl,-rpath,/usr/lib/x86_64-linux-gnu -rdynamic -m64 medmCartesianPlot.o medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o
medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o
medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o -lANLwidgets -lPrintUtils
-lca -lCom -lXm -lXt -lXmu -lX11 -lXext
/usr/bin/ld: cannot find -lXmu: No such file or directory
collect2: error: ld returned 1 exit status
make[2]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_BUILD:231: medm] Error 1
make[2]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm/O.linux-x86_64'
make[1]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm'
make: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_DIRS:85: medm.install] Error 2
- linux medm installation error: cannot find -lXmu Rong Huang via Tech-talk
Re: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
<2023>
2025
2026
#define usage in Sequencer Hyung Jin Kim via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
