1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Re: How do I setEPICS opc UA security Settings?
From: Ralph Lange via Tech-talk <[email protected]>
To: 谭映雷 <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Sat, 1 Apr 2023 15:19:29 +0200
Hello Yinglei Tan,
On Thu, 30 Mar 2023 at 15:04, 谭映雷 <[email protected]> wrote:
 I'm having trouble with OPC UA. How to use the 'setClientCertificate' command?
epics> opcuaShowSecurity
Certificate store:
  Server trusted certificates dir:
  Server revocation list dir:
  Issuer trusted certificates dir:
  Issuer revocation list dir:
  Rejected certificates are not saved.
ApplicationURI: urn:[email protected]:EPICS:IOC
No client certificate loaded.
Supported security policies:  Basic128Rsa15 Basic256 Basic256Sha256 None
epics> setClientCertificate
Command setClientCertificate not found.
epics>
Command setClientCertificate not found.How do I do that?
I am very sorry. The Security-README has an error at this point.
The correct iocShell command is "opcuaClientCertificate" - I have just fixed the readme on GitHub.
Tip: You can always use the "help" command in the iocShell to see the available commands or get usage information.
epics> help opcuaClientCertificate
Usage: opcuaClientCertificate 'certificate (public key) file' 'private key file'
Sets up the OPC UA client certificates to use for the IOC client.
certificate file  path to the file containing the certificate (public key)
private key file  path to the file containing the private key
Thanks for pointing this out!
Cheers,
~Ralph
How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
Re: Re: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Prev: Re: linux medm installation error: cannot find -lXmu Torsten Bögershausen via Tech-talk
Next: #define usage in Sequencer Hyung Jin Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Re: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Next: Use Maven to build the phoebus project White via Tech-talk
