1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Re: How do I setEPICS opc UA security Settings?
To: "ralph lange" <[email protected]>
Cc: epics tech talk <[email protected]>
Date: Thu, 30 Mar 2023 21:04:31 +0800 (GMT+08:00)
hello ralph lange:
Thank you for your guidance last time.
 I'm having trouble with OPC UA. How to use the 'setClientCertificate' command?
epics> opcuaShowSecurity
Certificate store:
  Server trusted certificates dir:
  Server revocation list dir:
  Issuer trusted certificates dir:
  Issuer revocation list dir:
  Rejected certificates are not saved.
ApplicationURI: urn:[email protected]:EPICS:IOC
No client certificate loaded.
Supported security policies:  Basic128Rsa15 Basic256 Basic256Sha256 None
epics> setClientCertificate
Command setClientCertificate not found.
epics>
Command setClientCertificate not found.How do I do that?
Regards
-----原始邮件-----
发件人:"Ralph Lange" <[email protected]>
发送时间:2023-03-29 21:58:07 (星期三)
收件人: "谭映雷" <[email protected]>
抄送: "EPICS Tech Talk" <[email protected]>
主题: Re: How do I setEPICS opc UA security Settings?
Hello Yinglei Tan,
Hi:
When I set up the EPICS OPC UA client, the server did not receive the reject (.der) file, but I did receive certificates from the server.
What should I do to create a client certificate? Should the client certificate be copied to the server?
Any suggestions/solution approaches are welcome.
In the OPC UA Device Support sources, you will find a detailed README about how to configure OPC UA Security.
Setting up X.509-based security is not simple. It can be very frustrating, as any small mistake will make the connection fail, often without clear error messages.
I would suggest that you start with getting a good understanding of how these certificates and the PKI infrastructure work.
Once you know what is required, the information in the README will be hopefully enough to get you going. (It obviously includes descriptions of the tools and commands necessary to create client certificates.)
Feel free to directly contact me when you get stuck again. This topic might be too specialized to be discussed on tech-talk. I will update the README with any additional information that should be added.
Cheers,
~Ralph
谭映雷 中国科学院高能物理研究所 电话:010-88235426
Re: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Prev: Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Hu, Yong via Tech-talk
Next: Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
Next: Re: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
