1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record
To: "Wang, Andrew" <[email protected]>, Mark Rivers <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 30 Mar 2023 12:43:39 +0000
Hi Andy,
Please take a look at the documentation: https://epics.anl.gov/bcda/synApps/std/sseqRecord.html. Specifically, this snippet “Finally, if the sseq record successfully waits for targetRecord to finish processing, … , and the sseq record cannot wait for this indirectly caused processing to finish unless …”.
I think this explains why DOL1/LNK1/WAIT1 does not work as you expect (you probably think that ‘FLNK’ will cause GET_PROP to be completely processed when SET_PROP gets processed) and you need additional DOL2/LNK2/WAIT2 to make GET_PROP completely processed.
As always, it is tricky to make asynchronous records (i.e. SET_PROP, GET_PROP) get processed as you expect.
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Date: Tuesday, March 28, 2023 at 6:00 PM
To: Mark Rivers <[email protected]>, EPICS tech-talk <[email protected]>
Subject: RE: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record
Hi Mark,
I totally forgot about that. Thank you for bringing that to my attention.
I attempted your suggestion by doing the following:
record(ao, “VAL”)
                field(SCAN, “Passive”)
record(sseq, “PROCESS_INST")
                field(SCAN,  "Passive")
                field(SELM,  "All")
field(DOL1, “VAL”)
                field(LNK1,  "SET_PROP CA")
                field(WAIT1, "Wait")
                field(FLNK, “PRINT_SET_AND_GET”)
record(aSub, “PRINT_SET_AND_GET")
                field(SNAM, “print_set_and_get”)
                field(INPA, “SET_PROP”)
                field(INPB, “GET_PROP”)
However, the values for SET_PROP and GET_PROP are still different when PRINT_SET_AND_GET processes.
To make it a little clearer, suppose that SET_PROP and GET_PROP both contain 25 initially. Then, I set VAL to be 55. Then, my hope would be that both SET_PROP and GET_PROP would both be 55 before PRINT_SET_AND_GET processes after I process PROCESS_INST. However, when PRINT_SET_AND_GET processes, SET_PROP is 55 but GET_PROP is still 25. If I process PROCESS_INST again, then both SET_PROP and GET_PROP are 55. My current workaround is doing the following, but it is very verbose. I still feel like the former method you proposed (if I understood it correctly) should work.
record(ao, “VAL”)
                field(SELM,  "All")
                field(DOL1, “VAL”)
                field(DOL2, “1”)
                field(LNK2,  "GET_PROP.PROC CA")
                field(WAIT2, "Wait")
Andy
Sent: Tuesday, March 28, 2023 5:11 AM
To: EPICS tech-talk <[email protected]>; Wang, Andrew <[email protected]>
Hi Andy,
I think your problem is with the WRITE_INST record in the second IOC.  It looks like perhaps you think that WRITE_INST will only write to the VAL field of SET_PROP, but not actually process the SET_PROP record.  Then you have PROCESS_INST that will process the SET_PROP record and wait for completion.
I think that would work if all of the records were in the same IOC.  However, the WRITE_INST link to SET_PROP is a CA link, and that will always cause the SET_PROP record to process if the field you are writing to has the PP attribute, which the VAL field does.  That is explained here:
which says:
The options for process passive are:
  • It is not possible to honor PP or NPP options; the put operation completes immediately but whether the destination record will process depends on the process passive attribute of the destination field.
  • CA - Force the link to be a channel access link.
So when WRITE_INST processes it forces SET_PROP to process, and then immediately links to PROCESS_INST.  PROCESS_INST will do a CA put, but SET_PROP will probably still be processing (PACT=TRUE).
If you combine WRITE_INST and PROCESS_INST into a single sseq record with WAIT1=Wait then I think it will do what you want.
I have not tested this, so I could be wrong.
Sent: Monday, March 27, 2023 10:58 PM
Subject: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record
Hi all,
Today I encountered something kind of interesting and would like to get some outside opinions.
To begin with, I have an IOC for an instrument that I shall call DemoInstr. I have a “setter” and “getter” record for one of its properties. The two records are shown below.
record(ao, “SET_PROP”)
                field(DTYP, “stream”)
field(PRIO, "HIGH")
                field(OUT,  "@DemoInstr.proto setProp $(PORT)")
                field(FLNK, “GET_PROP”)
record(ai, “GET_PROP”)
                field(INP,  "@DemoInstr.proto getProp $(PORT)")
In a separate IOC that I shall call Setup, I declared a SEQ record called “WRITE_INST” that should write a value into “setProp” when it is processed. Then, “PROCESS_INST”, a SSEQ record, will process because it is forward-linked to “WRITE_INST”. “PROCESS_INST” should wait for a completion callback with the way it is written. However, when “PRINT_SET_AND_GET” processes, it reports that GET_PROP still contains the previous value. Shouldn’t GET_PROP have been updated because of the completion callback? I feel like I am missing something in my understanding of completion callbacks.
record(ao, “VAL”)
record(seq, "WRITE_INST")
                field(SELM, "All")
                field(DOL1, “VAL")
                field(LNK1, "SET_PROP")
                field(FLNK, “PROCESS_INST ")
                field(SELM,  "All")
                field(LNK1,  "SET_PROP.PROC CA")
Thank you,
Andy
Purple ribbon awareness
Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Hu, Yong via Tech-talk
SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Wang, Andrew via Tech-talk
Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Mark Rivers via Tech-talk
RE: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Wang, Andrew via Tech-talk
Prev: Re: e_flex.exe error_base7.0.7 in win64 Ralph Lange via Tech-talk
Next: Re: Re: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Wang, Andrew via Tech-talk
Next: Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Hu, Yong via Tech-talk
