1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: e_flex.exe error_base7.0.7 in win64
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 30 Mar 2023 14:07:50 +0200
That bug was related to specific versions of the MinGW-w64 compiler and was fixed by switching to a newer compiler version. Probably unrelated.
You're using MSVC, so this doesn't apply, anyway.
Have you set up the environment for the MSVC correctly?
Please check the how-to at https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows.html. You need to run the MSVC-provided batch scripts to set up the environment before running make.
Cheers,
~Ralph
e_flex.exe error_base7.0.7 in win64 lynn via Tech-talk
Prev: e_flex.exe error_base7.0.7 in win64 lynn via Tech-talk
Next: Re: SSEQ record does not "appear" to be demanding callback completion from an asynchronous record forward-linked to another asynchronous record Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re:Re: e_flex.exe error_base7.0.7 in win64 lynn via Tech-talk
