1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: e_flex.exe error_base7.0.7 in win64
To: [email protected], tech-talk <[email protected]>
Date: Thu, 30 Mar 2023 18:24:22 +0800 (CST)
Hi Ralph,
   I got an error like these when make base 7.0.7 on win64.
   I found you have mentioned it in web https://bugs.launchpad.net/epics-base/+bug/1827225.
   But I did not get how to fix it.
   Could you do me a favor.
Output:
make (e=2): system can not find the file.
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../yacc/warshall.c, ...) failed.
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
Env:
base 7.0.7,win 64, VS2022
> choco list --local-only
Chocolatey v1.3.1
chocolatey 1.3.1
make 4.3
strawberryperl 5.32.1.1
lynn
Re: e_flex.exe error_base7.0.7 in win64 Ralph Lange via Tech-talk
Prev: Use Maven to build the phoebus project White via Tech-talk
Next: Re: e_flex.exe error_base7.0.7 in win64 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
