I believe I understand the problem. This is from the sequencer manual:
Depending on the application, it might be useful to pre-process the SNL source with a C pre-processor (cpp).
Using the C pre-processor allows you to include other SNL files, define macros, and perform conditional compilation. snc supports
this by interpreting cpp-generated
line markers, so that error and warning messages refer to the line numbers in the un-pre-processed SNL source.
The build rules that the sequencer adds to the EPICS build system are such that files with the extension .st are
preprocessed, while those with the extension .stt are
not.
So if you name your file .stt then the C pre-processor is not run. But #define is handled by the C pre-processor. So you need to name your file .st not .stt.
I tested this on my system, and I get the same error as you if the file is named .stt, but it works fine if it is named .st.
Dear All,
I tried to set a size of array using predefined value in sequencer code as follows:
program sncTest
#define A_SIZE 3
double test_array[A_SIZE];
assign test_array to {"{S}:r1", "{S}:r2", "{S}:r3"};
monitor test_array;
However, it gives an error when it is compiled. #define is not allowed in sequencer. An used sequencer version is 2-2-6.
../sncTest.stt:3: lexical error: invalid character
../sncTest.stt:3: syntax error near token ''
../sncTest.stt:3: parser giving up
- Re: #define usage in Sequencer Hyung Jin Kim via Tech-talk
- #define usage in Sequencer Hyung Jin Kim via Tech-talk
- Re: #define usage in Sequencer Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
