Dear Mark,
After my sequencer file is renamed as ".st", it works fine.
Best regards,
HJ
On 4/3/23 00:22, Mark Rivers wrote:
I believe I understand the problem.
This is from the sequencer manual:
Depending
on the application, it might be useful to pre-process the
SNL source with a C pre-processor (cpp). Using the
C pre-processor allows you to include other SNL files,
define macros, and perform conditional compilation. snc supports this by interpreting cpp-generated
line markers, so that error and warning messages refer to
the line numbers in the un-pre-processed SNL source.
The
build rules that the sequencer adds to the EPICS build
system are such that files with the extension .st are preprocessed, while those with the extension .stt are not.
So if you name your file .stt then
the C pre-processor is not run. But #define is handled by the
C pre-processor. So you need to name your file .st not .stt.
I tested this on my system, and I get the same error
as you if the file is named .stt, but it works fine if it is
named .st.
Dear All,
I tried to set a size of array
using predefined value in sequencer
code as follows:
program sncTest
#define A_SIZE 3
double test_array[A_SIZE];
assign test_array to {"{S}:r1",
"{S}:r2", "{S}:r3"};
monitor test_array;
However, it gives an error when it
is compiled. #define is not allowed in
sequencer. An used sequencer version
is 2-2-6.
../sncTest.stt:3: lexical error:
invalid character
../sncTest.stt:3: syntax error near
token ''
../sncTest.stt:3: parser giving up
- #define usage in Sequencer Hyung Jin Kim via Tech-talk
- Re: #define usage in Sequencer Mark Rivers via Tech-talk
03/04/2023 19:01:51 自动保存草稿 lynn via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
