1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Fw:Re:Re: e_flex.exe error_base7.0.7 in win64
To: "[email protected]" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 12 Apr 2023 13:02:04 +0800 (CST)
Sorry, base was maked well.
Maybe forget the environement variable.
-------- 转发邮件信息 --------
发件人:"lynn" <[email protected]>
发送日期:2023-04-11 15:48:08
收件人:"Ralph Lange" <[email protected]>,tech-talk <[email protected]>
主题:Re:Re: e_flex.exe error_base7.0.7 in win64
Hi Ralph,
    Now I tried to install epics using mingw. (success once using Visual Stdio, but then failed, so i want to use msys2 ).
    But  the error "ccl.obj e_flex.exe "still came out.
   1) pacman -S mingw-w64-x86_64-toolchain
   2) export EPICS_HOST_ARCH=windows-x64-mingw
3) others and "make"
4) I uninstalled VS and reboot, nothing changed.
Output of make:
cketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
make[4]: cl: No such file or directory
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
make[4]: Leaving directory '/home/dell/base-7.0.7/modules/libcom/src/O.windows-x64'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[3]: Leaving directory '/home/dell/base-7.0.7/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/home/dell/base-7.0.7/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory '/home/dell/base-7.0.7/modules'
OS:
   Win 11_64 HOME
Msys2:
Base:
  7.0.4.1 and I tried 7.0.7 also
$ gcc --version
gcc.exe (Rev10, Built by MSYS2 project) 12.2.0
Copyright (C) 2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
$ make -version
GNU Make 4.4.1
Built for x86_64-pc-msys
Copyright (C) 1988-2023 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <https://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Regards.
Lynn
At 2023-03-30 20:03:51, "Ralph Lange" <[email protected]> wrote:
That bug was related to specific versions of the MinGW-w64 compiler and was fixed by switching to a newer compiler version. Probably unrelated.
You're using MSVC, so this doesn't apply, anyway.
Have you set up the environment for the MSVC correctly?
Please check the how-to at https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows.html. You need to run the MSVC-provided batch scripts to set up the environment before running make.
Cheers,
~Ralph
On Thu, 30 Mar 2023 at 12:24, lynn <[email protected]> wrote:
Hi Ralph,
   I got an error like these when make base 7.0.7 on win64.
   I found you have mentioned it in web https://bugs.launchpad.net/epics-base/+bug/1827225
   But I did not get how to fix it.
   Could you do me a favor.
Output:
make (e=2): system can not find the file.
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../yacc/warshall.c, ...) failed.
Env:
base 7.0.7,win 64, VS2022
> choco list --local-only
Chocolatey v1.3.1
chocolatey 1.3.1
make 4.3
strawberryperl 5.32.1.1
lynn
Prev: Does anyone have good connections to Agilent? Epics for gas chromatographs/mass spectrometers junkes via Tech-talk
Next: Re: Does anyone have good connections to Agilent? Epics for gas chromatographs/mass spectrometers Ulrik Pedersen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Re: e_flex.exe error_base7.0.7 in win64 Ralph Lange via Tech-talk
Next: Mobile web client for PSI Elog Wang, Lin via Tech-talk
