1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: areadetector on windows, xml2 done, now Lightfield
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: William Kirstaedter <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Apr 2023 22:12:19 +0000
Hi William,
lightfield may load it dynamically at runtime then (like areadetector) and so it will not show up in dependencywalker. Loading ARC_Instrument_x64.dll itself into dependencywalker may be most useful then,  one possible cause of the problem you are seeing is that ARC_Instrument_x64.dll is loading an incompatible dependent library when activated by EPICS and dependencywalker will show the dependent libraries it uses and may give some clues to this.
One difference between running LightfieldApp.exe directly and loading the library via areadetector is that the directory containing the LightfieldApp.exe program will automatically get added as the first place to look for any DLL dependencies of ARC_Instrument_x64.dll. Is the lightfield directory already in PATH? If not, one thing to try first is to edit your start_epics.bat so after running dllPath.bat it then does
    set “PATH=%LIGHTFIELD_ROOT%;%PATH%”
so the directory that contains lightfield.exe is searched first for any DLL dependencies
Freddie
Sent: 12 April 2023 16:23
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Subject: Re: areadetector on windows, xml2 done, now Lightfield
Hey Freddie, I think I might need some guidance on this.
I loaded my IOCs LightfieldApp.exe and also the Princeton.Lightfield.exe (this does not load anything ?!) in dependencywalker, but none of them seems to load the ARC_...dll.
is there a better way than loading and scrolling through the list to search for my ARC.dll?
it wasnt obvious :(
thanks,
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 28.03.2023 um 01:02 schrieb Freddie Akeroyd - STFC UKRI:
In other situations I have seen DLL load errors caused by a dependency of the DLL in question not being found i.e. ARC_Instrument_x64.dll may be present in the right place but one of the DLLs it depends on (and is located via the PATH environment variable) might be either not found or an old/incorrect version of this required file was installed by another program which happens to be earlier in PATH and so is picked up instead. Programs like dependency walker   https://www.dependencywalker.com/  can help locate such clashes if that is the problem
Freddie
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: 27 March 2023 23:21
To: William Kirstaedter <[email protected]>; tech-talk <[email protected]>
Hi William,
I am trying to understand why you get that missing DLL error.
Can run the camera OK using LightField as a stand-alone application without EPICS?
Do you have more than one version of LightField installed?
ADLightField does not call that DLL explicitly, it just starts LightField in this line:
https://github.com/areaDetector/ADLightField/blob/3383118260b82d95255f303d673e04d4de0123c9/lightFieldApp/src/LightField.cpp#L410
The missing DLL is ARC_Instrument_x64.dll.  I have attached a screen shot showing the size and location of that file on my system.  What do you see on your system?
RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Re: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
RE: areadetector on windows, xml2 done, now Lightfield Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
Next: RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
