1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: modbus ioc start
To: Torsten Bögershausen <[email protected]>
Date: Fri, 14 Apr 2023 13:57:48 -0500
Torsten,
Here it is:
epics> asynReport 10 Z8TC1_Config
Z8TC1_Config multiDevice:Yes canBlock:Yes autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 4 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 0 exceptionNotifys 0
    traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
    interposeInterfaceList
        asynOctet pinterface 0x7f2974234460 drvPvt 0x555800dc6c50
    interfaceList
        asynCommon pinterface 0x7f2974234d10 drvPvt 0x555800dc5170
        asynDrvUser pinterface 0x7f2974234aa0 drvPvt 0x555800dc5170
        asynOctet pinterface 0x7f2974234be0 drvPvt 0x555800dc5170
        asynUInt32Digital pinterface 0x7f2974234c60 drvPvt 0x555800dc5170
        asynInt32 pinterface 0x7f2974234ce0 drvPvt 0x555800dc5170
        asynInt64 pinterface 0x7f2974234ca0 drvPvt 0x555800dc5170
        asynFloat64 pinterface 0x7f2974234c40 drvPvt 0x555800dc5170
        asynInt32Array pinterface 0x7f2974234b80 drvPvt 0x555800dc5170
    addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
        exceptionActive No exceptionUsers 0 exceptionNotifys 0
        blocked No
    addr 1 autoConnect Yes enabled Yes connected Yes exceptionActive No
        blocked No
    addr 2 autoConnect Yes enabled Yes connected Yes exceptionActive No
        blocked No
    addr 3 autoConnect Yes enabled Yes connected Yes exceptionActive No
        blocked No
modbus port: Z8TC1_Config
    initialized:        true
    asynOctet server:   SenecaBus
    modbusSlave:        5
    modbusFunction:     6
    modbusStartAddress: 065
    modbusLength:       04
    absoluteAddressing: false
    dataType:           4 (UINT16)
    plcType:            SenecaZ
    I/O errors:         0
    Read OK:            1
    Write OK:           0
    pollDelay:          0.400000
    Time for last I/O   21 msec
    Max. I/O time:      21 msec
    Time per hist. bin: 1 msec
Port: Z8TC1_Config
  Timestamp: <undefined>
  Input EOS[0]:
  Output EOS[0]:
Parameter list 0
Number of parameters is: 12
Parameter 0 type=asynInt32, name=MODBUS_DATA, value is undefined
Parameter 1 type=asynInt32, name=MODBUS_READ, value is undefined
Parameter 2 type=asynUInt32Digital, name=ENABLE_HISTOGRAM, value is undefined
Parameter 3 type=asynInt32, name=READ_HISTOGRAM, value is undefined
Parameter 4 type=asynInt32, name=HISTOGRAM_BIN_TIME, value is undefined
Parameter 5 type=asynInt32Array, name=HISTOGRAM_TIME_AXIS, value is undefined
Parameter 6 type=asynFloat64, name=POLL_DELAY, value is undefined
Parameter 7 type=asynInt32, name=READ_OK, value=1, status=0
Parameter 8 type=asynInt32, name=WRITE_OK, value=0, status=0
Parameter 9 type=asynInt32, name=IO_ERRORS, value=0, status=0
Parameter 10 type=asynInt32, name=LAST_IO_TIME, value=21, status=0
Parameter 11 type=asynInt32, name=MAX_IO_TIME, value=21, status=0
On Fri, Apr 14, 2023 at 1:46 PM Torsten Bögershausen <[email protected]> wrote:
I have the slight feeling, but this is a shot into the blue,
that the driver is doing the right thing.
And may be the record is initialized to early ?
What does
give you ?
Do you see the right values in the asynparameters ?
> On 14 Apr 2023, at 15:43, Dale Cox via Tech-talk <[email protected]> wrote:
> Thanks for the reply Mark.
> (1) Yes I thought this was the case.  Whenever I enable some asyn trace lines in the IOC, I can see the initial modbus request. It looks like this:
> drvModbusAsynConfigure("Z8TC1_Config", "SenecaBus", 5, 6, 53, 4, "UINT16", 400, "SenecaZ")
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort locking port
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort created queueLockPortPvt=0x55ec3aba5df0
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort created queueLockPortPvt=0x55ec3aba5df0, event=0x55ec3aba5e10, mutex=0x55ec3aba5eb0
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort taking mutex 0x55ec3aba5eb0
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort queueing request
> 2023/04/14 08:32:01.482 SenecaBus addr -1 queueRequest priority 0 not lockHolder
> 2023/04/14 08:32:01.482 SenecaBus schedule queueRequest timeout in 2.000000 seconds
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort waiting for event
> 2023/04/14 08:32:01.482 asynManager::portThread port=SenecaBus callback
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPortCallback signaling begin event
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
> 2023/04/14 08:32:01.482 SenecaBus asynManager::queueLockPort got event from callback
> 2023/04/14 08:32:01.482 SenecaBus flush
> 2023/04/14 08:32:01.482 /dev/ttyUSB0 flush
> 2023/04/14 08:32:01.487 /dev/ttyUSB0 write.
> 2023/04/14 08:32:01.487 /dev/ttyUSB0 write 8
> 05 03 00 35 00 04 55 83
> 2023/04/14 08:32:01.487 wrote 8 to /dev/ttyUSB0, return asynSuccess
> 2023/04/14 08:32:01.487 asynOctetSyncIO wrote:
> 05 03 00 35 00 04
> 2023/04/14 08:32:01.487 /dev/ttyUSB0 read.
> 2023/04/14 08:32:01.495 /dev/ttyUSB0 read 13
> 05 03 08 d0 11 d2 00 d2 00 d2 11 3b 1c
> 2023/04/14 08:32:01.495 /dev/ttyUSB0 read 13, return 0
> 2023/04/14 08:32:01.495 SenecaBus read 13 bytes eom=0
> 2023/04/14 08:32:01.495 asynOctetSyncIO read:
> 2023/04/14 08:32:01.495 SenecaBus queueUnlockPort
> 2023/04/14 08:32:01.495 SenecaBus asynManager::queueUnlockPort waiting for event
> 2023/04/14 08:32:01.495 SenecaBus queueUnlockPort unlock mutex 0x55ec3aba5eb0 complete.
> So I'm getting the requested registers back on that port, and you can see their values there.  d0 11 is 1101000000010001 in binary, so when I look at the 15th bit, it should return back a 1.  when I do a caget on that PV, I get a 0 (I get 0's for all of the records associated with these registers).
> Is it supposed to say "asynSuccess" at the end of the highlighted section?  I get a "return 0".
> Thanks for helping me troubleshoot.
> Dale
> On Thu, Apr 13, 2023 at 4:38 PM Mark Rivers <[email protected]> wrote:
> Hi Dale,
>       • My issue is that the PV values aren't being updated when the IOC starts -- meaning that after the IOC start, the bo and mbbo values stored in that register don't match what was returned via the initial modbus request.
> I am not sure I completely understand what you are saying.  Here is what should happen:
>       • Because this port you created uses function code 6 (write single register) and because you have a non-zero poll time, the driver will do one initial read of that register using function code 3.
>       • EPICS device support for the bo records does a read operation from the port during init_record.  If this read returns asynSuccess (which it should) then the value of the bo record is set to the value read from the driver.  This is the “bumpless reboot” concept.
>       • You have not set PINI=YES in these records, so the value from the record will not be written back to the device during iocInit.  However, the record value should still match the device, because of steps 1 and 2 above.
> If I understand correctly you are saying that the bo record does have the correct value read from the device during steps 1-2.  But now the device has a different value from that in the record?  I don’t understand that, since it seems like there must have been a write to the device to change the value?
> Mark
> From: Tech-talk <[email protected]> On Behalf Of Dale Cox via Tech-talk
> Sent: Thursday, April 13, 2023 8:29 AM
> To: [email protected]
> Subject: modbus ioc start
> Good Morning,
> I have an IOC that is currently reading registers via modbus rtu over rs485.  There are a set of registers that store multiple configuration options in a single register.  I set up the port using this line:
> > drvModbusAsynConfigure("Z8TC1_Config", "SenecaBus", 5, 6, 53, 4, "UINT16", 100, "SenecaZ")
> I've enabled the debugging lines on this IOC. When the IOC starts, I can see that the correct registers are being retrieved when the port is created.  I can also write config changes to those registers at their assigned PV's with no issues that I have found.  My issue is that the PV values aren't being updated when the IOC starts -- meaning that after the IOC start, the bo and mbbo values stored in that register don't match what was returned via the initial modbus request.
> Here are a couple of the DB entries that I'm using:
> record(bo,"$(P)$(R)-TC1_enable") {
>     field(DTYP,"asynUInt32Digital")
>     field(OUT,"@asynMask($(PORT), 0, 0x8000 )")
>     field(ZNAM,"Disabled")
>     field(ONAM,"Enabled")
> record(bo,"$(P)$(R)-TC2_enable") {
>     field(OUT,"@asynMask($(PORT), 0, 0x4000 )")
> record(bo,"$(P)$(R)-TC1-2_units") {
>     field(OUT,"@asynMask($(PORT), 0, 0x2000 )")
>     field(ZNAM,"tempDegC")
>     field(ONAM,"mV")
> Any help is appreciated.
> Dale
> Dale Cox
> Instrumentation and Electrical Engineer
> ACU NEXT Lab
Re: modbus ioc start Torsten Bögershausen via Tech-talk
RE: modbus ioc start Mark Rivers via Tech-talk
modbus ioc start Dale Cox via Tech-talk
Re: modbus ioc start Dale Cox via Tech-talk
Prev: Re: modbus ioc start Torsten Bögershausen via Tech-talk
Next: Re: modbus ioc start Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
