1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Re:Re: areaDetector error in mingw, windows
To: lynn <[email protected]>
Date: Sat, 15 Apr 2023 15:48:35 +0000
On further thought I don't see how you can use mingw with the Xspress3.  The EPICS driver calls the vendor driver using a library, and does not communicate over sockets.  The EPICS driver thus needs to run on the same computer as the vendor library and hardware interfaces.  I believe the vendor only support 64-bit Linux.  So I don't think you can use mingw and Windows.
Sent: Saturday, April 15, 2023 10:35 AM
Cc: [email protected] <[email protected]>; tech-talk <[email protected]>
Hi Lynn,
The xspress3 module explictly restricts its builds to the linux-x86_64 architecture in these 2 lines in the Makefiles:
I am not sure if that restriction is necessary or not.  You try adding mingw to those Makefiles and see if it works.
Sent: Friday, April 14, 2023 4:57 AM
Subject: Re:Re: areaDetector error in mingw, windows
Hi Mark and Ralph,
   Thank you for your answer. I choose an easy way, set WITH_GRAPHICSMAGICK=NO and work well.
Actually, I intend to use xspress3 module in mingw of windows.
And i did these thing and met some error again.
1) i installed xspress3 module well, but there isn't bin file( mingw-64, base7.0.7, asyn, areaDetector and others good).
I want to know. Could I do some setting, make the bin file of xspress3 came out directly after make command?
2) Since there isn't bin file, I try: [1] create an ioc using makeBaseApp.pl.  [2] add st.cmd of xspess.
But something wrong during [1].
I did these:
    (a) type: $(BASE)/bin/windows-x64-mingw/makeBaseApp.pl -t example example
    (b) type: $(BASE)/bin/windows-x64-mingw/makeBaseApp.pl -i -t example example
    (c) choose windos-x64-mingw,
   The following target architectures are available in base:
    windows-x64
    windows-x64-mingw
         P.S. There are two file in my &(BASE)/bin/.   "window-x64" and "windows-x64-mingw"
    (d) make, no error
    (e) start the ioc
$ ../../bin/windows-x64-mingw/example.exe st.cmd
#!../../bin/windows-x64-mingw/example
< envPaths
epicsEnvSet("IOC","iocexample")
epicsEnvSet("TOP","/home/dell/all")
epicsEnvSet("EPICS_BASE","/home/dell/base-7.0.7")
cd "/home/dell/all"
Invalid directory path, ignored
dbLoadDatabase "dbd/example.dbd"
filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file dbd/example.dbd
example_registerRecordDeviceDriver pdbbase
registerRecordDeviceDriver failed aSub
registerRecordDeviceDriver failed aai
registryJLinkAdd failed trace
registryJLinkAdd failed pva
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadTemplate: error opening sub file db/user.substitutions
dbLoadRecords "db/exampleVersion.db", "user=dell"
filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file db/exampleVersion.db
dbLoadRecords: failed to load 'db/exampleVersion.db'
dbLoadRecords "db/dbSubExample.db", "user=dell"
filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file db/dbSubExample.db
dbLoadRecords: failed to load 'db/dbSubExample.db'
cd "/home/dell/all/iocBoot/iocexample"
iocInit
Starting iocInit
checkDatabase: menuConvert not defined.
iocBuild: Aborting, bad database definition (DBD)!
Base 7.0.7 was right. These process should be good in linux. I don't know what is wrong with it.
So could someone do me a favor. I just want to use xspress in mingw.
Lynn
在 2023-04-13 21:31:14,"Mark Rivers" <[email protected]> 写道:
Hi Lynn,
You probably don't really need GraphicsMagick.  I suggest you changed areaDetector/configure/CONFIG_SITE.local to set WITH_GRAPHICSMAGICK=NO.
See if you then get any other errors.
From: Tech-talk <[email protected]> on behalf of lynn via Tech-talk <[email protected]>
Sent: Thursday, April 13, 2023 5:38 AM
To: tech-talk <[email protected]>
Subject: areaDetector error in mingw, windows
    I want to use areaDetector, using Ming 64,Windows Home 64.
    base 7.0.7, asyn, areaDetector and other module are all new version from git.
    I am not quite sure about how to install it, using windows lib and software. But I know linux way, so i install it just like linux OS, except EPICS_HOST_ARCH or something.
I did these, before i make areaDetector :
1) base,asyn, busy and other module was installed well and prepare areaDetector( ADSupport, ADCore)
2) cp and modify  release.local, release_libs.local,release_prods.local,config_site.local
3) make and error came out( error message at bottom)
4) Then I tried CONFIG_SITE.local.linux-x86.win32-x86-mingw,CONFIG_SITE.local.linux-x86.win32-x86-mingw-static  and CONFIG_SITE.local.WIN32, all  failed.
5) I also try to configure areaDetector, using GraphicsMagick external, still in mingw environment.
configure && make :
libtool:   error: Could not determine host file name corresponding to
libtool:   error:   'Magick++/lib/.libs/' :
And I want to know:
Considering i did much work using linux way in mingw environment.
1) how to fix the error below?
2) if you have better way, please let me know it.
Output of areaDetector make: (in Mingw 64)
 C:/msys64/mingw64/include/objidl.h:11436:11: error: reference to 'byte' is ambiguous
11436 |     const byte *pv,
C:/msys64/mingw64/include/c++/12.2.0/bits/cpp_type_traits.h:406:30: note: candidates are: 'enum class std::byte'
  406 |   enum class byte : unsigned char;
C:/msys64/mingw64/include/rpcndr.h:63:25: note:                 'typedef unsigned char byte'
   63 |   typedef unsigned char byte;
In file included from C:/msys64/mingw64/include/msxml.h:311,
                 from C:/msys64/mingw64/include/urlmon.h:458,
                 from C:/msys64/mingw64/include/objbase.h:163:
C:/msys64/mingw64/include/oaidl.h:587:5: error: reference to 'byte' is ambiguous
  587 |     byte *pRecord;
make[6]: *** [/home/dell/base-7.0.7/configure/RULES_BUILD:267: Image.obj] Error 1
make[6]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib/O.windows-x64-mingw'
make[5]: *** [/home/dell/base-7.0.7/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[5]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib'
make[4]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: lib.install] Error 2
make[4]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++'
make[3]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: Magick++.install] Error 2
make[3]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc'
make[2]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: GraphicsMagickSrc.install] Error 2
make[2]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp'
make[1]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: supportApp.install] Error 2
make[1]: Leaving directory '/home/dell/areaDetector-master/ADSupport'
make: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: /home/dell/areaDetector-master/ADSupport.install] Error 2
$ uname -a
MINGW64_NT-10.0-22000 DESKTOP-M04F14I 3.4.6.x86_64 2023-04-01 11:43 UTC x86_64 Msys
$ gcc --version
gcc.exe (Rev10, Built by MSYS2 project) 12.2.0
$ make --version
GNU Make 4.4.1
Built for x86_64-pc-msys
Lynn
areaDetector error in mingw, windows lynn via Tech-talk
Re: areaDetector error in mingw, windows Mark Rivers via Tech-talk
Re:Re: areaDetector error in mingw, windows lynn via Tech-talk
Re: Re:Re: areaDetector error in mingw, windows Mark Rivers via Tech-talk
Prev: Re: Re:Re: areaDetector error in mingw, windows Mark Rivers via Tech-talk
Next: areadetector compile error "X11/extensions/shae.h" no such file whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: modbus ioc start Dale Cox via Tech-talk
