1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: areadetector compile error "X11/extensions/shae.h" no such file
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Sun, 16 Apr 2023 11:23:32 +0900
Can you please any idea to solve this problem?
Epics base v: 3.15.6
Synapps v: 6.1
I tried to compile areadetector and it shows me this error:
../xwindow.c:73:12: fatal error: X11/extensions/shape.h: No such file or directory
#  include <X11/extensions/shape.h>
compilation terminated.
make[5]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_BUILD:232: xwindow.o] Error 1
make[5]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc/magick/O.linux-x86_64'
make[4]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc/magick'
make[3]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: magick.install] Error 2
make[3]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc'
make[2]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: GraphicsMagickSrc.install] Error 2
make[2]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp'
make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: supportApp.install] Error 2
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport'
make: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: /usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport.install] Error 2
[root@localhost areaDetector-R3-7]# sudo yum install libxcomposite-dev libxdamage-dev
I installed libX11-devel-1.6.8-5.el8.x86_64, libXext-1.3.4-1.el8.x86_64, libxml2-2.9.7-15.el8_7.1.x86_64, libtiff-4.0.9-26.el8_7.x86_64, libX11-1.6.8-5.el8.x86_64
What should I package do I have to install more??
Re: areadetector compile error "X11/extensions/shae.h" no such file Mark Rivers via Tech-talk
Prev: Re: Re:Re: areaDetector error in mingw, windows Mark Rivers via Tech-talk
Next: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Motor module compile (dbdExpand.pl:can't find file asSupport.dbd) Kevin Peterson via Tech-talk
Next: Re: areadetector compile error "X11/extensions/shae.h" no such file Mark Rivers via Tech-talk
