1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: areadetector compile error "X11/extensions/shae.h" no such file
To: "[email protected]" <[email protected]>, whitetiger1123 <[email protected]>
Date: Sun, 16 Apr 2023 12:41:37 +0000
It looks like you are running on an RHEL8 or related system.  You can see what packages provide shape.h with this command.  I ran this on my Centos8 Stream system.
[epics@viper ~]$ dnf provides '*/shape.h'
libXext-devel-1.3.4-1.el8.i686 : X.Org X11 libXext development package
Repo        : appstream
Matched from:
Filename    : /usr/include/X11/extensions/shape.h
So you need to install libXext-devel.  You can only installed libXext.
From: Tech-talk <[email protected]> on behalf of whitetiger1123 via Tech-talk <[email protected]>
Sent: Saturday, April 15, 2023 9:23 PM
To: [email protected] <[email protected]>
Subject: areadetector compile error "X11/extensions/shae.h" no such file
Can you please any idea to solve this problem?
Epics base v: 3.15.6
Synapps v: 6.1
I tried to compile areadetector and it shows me this error:
../xwindow.c:73:12: fatal error: X11/extensions/shape.h: No such file or directory
#  include <X11/extensions/shape.h>
compilation terminated.
make[5]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_BUILD:232: xwindow.o] Error 1
make[5]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc/magick/O.linux-x86_64'
make[4]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc/magick'
make[3]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: magick.install] Error 2
make[3]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp/GraphicsMagickSrc'
make[2]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: GraphicsMagickSrc.install] Error 2
make[2]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport/supportApp'
make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: supportApp.install] Error 2
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport'
make: *** [/usr/local/epics/main/base-3.15.6/configure/RULES_DIRS:84: /usr/local/epics/main/modules/synApps_6_1/support/areaDetector-R3-7/ADSupport.install] Error 2
[root@localhost areaDetector-R3-7]# sudo yum install libxcomposite-dev libxdamage-dev
I installed libX11-devel-1.6.8-5.el8.x86_64, libXext-1.3.4-1.el8.x86_64, libxml2-2.9.7-15.el8_7.1.x86_64, libtiff-4.0.9-26.el8_7.x86_64, libX11-1.6.8-5.el8.x86_64
What should I package do I have to install more??
areadetector compile error "X11/extensions/shae.h" no such file whitetiger1123 via Tech-talk
Prev: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) whitetiger1123 via Tech-talk
Next: Re: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: areadetector compile error "X11/extensions/shae.h" no such file whitetiger1123 via Tech-talk
Next: motor sub module compiile error (make[1]: *** [/usr/local/epics/main/base-3.15.6/configure/RULES.ioc:34: envPaths] Error 2) whitetiger1123 via Tech-talk
