1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: About "Identical process variable names on multiple servers" with invalid address
From: Andrew Johnson via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 20 Apr 2023 13:16:41 -0500
Hi Emilio,
This sounds like an interesting story! Before your report gets lost in the archives, could you turn it into either an GitHub issue or even better a pull-request against the 7.0 branch of EPICS Base please. That will ensure the core developers will remember to discuss it.
- Andrew
On 4/18/23 4:48 AM, Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk wrote:
Hi all, I hope you are well
Today, I would like to mention an interesting issue that manifest itself in camonitor (with any PV, no matter the server) as follows:
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "SR-DI-DCCT-01:SIGNAL.NAME", Connecting to: cs03r-cs-gate-01.cs.diamond.ac.uk:5064, Ignored: 0.0.0.1:5"
    Source File: ../cac.cpp line 1308
The problem has been identified and it is caused by a series of unfortunate events described below:
  1. Some IOC was mistakenly started with EPICS_CA_SERVER_PORT=5065
  2. That IOC contains CA links that will try and retry (forever) to send CA_PROTO_SEARCH request messages (using port 5065)
  3. Meanwhile, in the same network, there is one or many CA clients to random PVs, the caRepeater will forward the CA_PROTO_SEARCH request message to every CA client (mistakenly thinking that it is a beacon message)
  4. The CA client mistakenly parses the CA_PROTO_SEARCH request thinking that is a CA_PROTO_SEARCH response (given that channel access doesn't have any flag to indicate if it's a request or a response)
  5. The CA client will check the last field of the header of CA_PROTO_SEARCH message which in both cases (reply and response) correspond to the Search ID... this means the message is most of the times discarded because of a non-matching search ID, but because the faulty IOC is sending CA_PROTO_SEARCH requests continuously (starting with low values of search ID), it eventually clashes with the Search ID that that client used.
  6. The CA client will mistakenly parse the fields server port and IP which results in the message with invalid IP shown above
Now, I would like to suggest a solution (which I think is simpler than the alternatives)... according to the CA spec, the data type field of the CA_PROTO_SEARCH response should be 0, while in the response, the same offset is the version and shouldn't be 0, therefore, we can use that for filtering the CA_PROTO_SEARCH  request. My proposal is reflected in the following patch (which hasn't been tested but should work):
diff --git a/modules/ca/src/client/udpiiu.cpp b/modules/ca/src/client/udpiiu.cpp
index c6ffb6def..27f91f5ad 100644
--- a/modules/ca/src/client/udpiiu.cpp
+++ b/modules/ca/src/client/udpiiu.cpp
@@ -680,6 +680,13 @@ bool udpiiu :: searchRespAction (
         return true;
+     * CA requires this field to be 0 in the search response
+    if (msg.m_dataType != 0) {
+        return true;
      * Starting with CA V4.1 the minor version number
      * is appended to the end of each UDP search reply.
I hope you also find this issue interesting,
Kind Regards,
Emilio
Complexity comes for free, Simplicity you have to work for.
Re: About "Identical process variable names on multiple servers" with invalid address Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: External: opc ua client Niko Kivel via Tech-talk
Next: Re: Search all PV available Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: About "Identical process variable names on multiple servers" with invalid address Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: About "Identical process variable names on multiple servers" with invalid address Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
