1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: Sequencer configuration file
From: "David A. Slimmer via Tech-talk" <[email protected]>
Cc: "David A. Slimmer" <[email protected]>
Date: Tue, 2 May 2023 18:25:11 +0000
Thanks for your suggestions. While I was able to use g++, I ran into what appears to be scoping problems that I could not overcome.
I decided to do a quick rewrite of my code in c. While that solves my initial problem, I’ve run into a problem trying to a launch a thread which is necessary for the PVPUT in the _seq.st code:
state reading
  biasmoduleThread();
  when(available)
                PVPUT(status, temphumRead( &h, &t ));
Produces this error:
So the sequencer parser doesn’t like my call to biasmoduleThread(), although there is no error produced from temphumRead(). I’m guessing temphumRead is handled differently because it is the context of a PVPUT call.
If launching a thread in the _seq.st code is not a proper thing to do, I’m wondering if there is another way to handle the thread launch before the sequencer starts?
Dave
Sent: Tuesday, April 18, 2023 7:41 PM
To: Michael Davidsaver <[email protected]>; David A. Slimmer <[email protected]>
Cc: [email protected]
Subject: Re: Sequencer configuration file
On 4/18/23 5:55 PM, Michael Davidsaver wrote:
On 4/18/23 13:28, Andrew Johnson via Tech-talk wrote:
The first thing I would try would be to change the seq/configure/RULES_BUILD ...
Recent versions move these rules to configure/RULES_SNCSEQ,
which is then installed as cfg/RULES_SNCSEQ where it is automatically
included by every package which includes this module in configure/RELEASE.
Rules can still be placed in a configure/RULES_BUILD file as this file still gets automatically included by every package that lists this module in their configure/RELEASE file(s). That feature was originally added to allow the sequencer to provide build rules for its customers, but the approach involving installed cfg/RULES_* files was introduced more recently, and we do now encourage module authors to switch to using that instead.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Sequencer configuration file Andrew Johnson via Tech-talk
Sequencer configuration file David A. Slimmer via Tech-talk
Re: Sequencer configuration file Michael Davidsaver via Tech-talk
Prev: Re: External: Questions about Function: epicsEventWaitWithTimeout (id, timeout) Niko Kivel via Tech-talk
Next: Re: Sequencer configuration file Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Sequencer configuration file Andrew Johnson via Tech-talk
